Firstly never try to use local battery because they are not good enough and damages handset . check your battery in other mobile if its works in other mobile then your handset need to be FLASHING ie. updation is required. Update your handset and never use local battery always use nokia brand. Thanks to help you
Congratulations!!! remove every parts you can i.e. battery, SIM card and memory card. Make sure each and every single drop of water is out. Wrap the mobile phone thick with a piece of cloth and keep it on a warm place ( Not too warm ) like Above the TV( thats the best i can suggest) for couple of days, 3-4 days will be sufficient. Make sure you don't switch it ON while its wet otherwise the Flash IC might get fried by the battery. After 3-4days of evaporating the water from your Mobile, keep fingers crossed and switch ON the Mobile. If switched ON perfectly for 10-15 minutes (try checking all the feature in this time period) the mobile phone is in good status and if it doesn't kindly purchase a new Phone because i won't suggest you to get it repaired as once Nokia phone goes for a repairing it will always ask for repairing after 2-3 months.
Well, you can try this; Check the behavior of the phone with a new battery and see. A battery problem could cause this. If this does not work, then you would have to check if no key on the phone is stuck. But the second is not likely since a stuck key would cause a phone to freeze. If this does not solve it, then you would have to see a nearest mobile phone technician since it will be an internal problem on the main board which will require the hands of an experienced person. Thanks
