Tip & How-To about Apple iPod touch
It is advisable to listen to your iPod through headphones
while driving in the car. Not only is it dangerous to completely cancel the
sounds of the road as it is often illegal in many cities across the country.
There is an alternative, however. In just a few steps you can use your iPod to
your car stereo speakers and use the car to listen to your music, podcasts and
audiobooks. No brand car stereo makes it easier to connect these beautiful than
Pioneer.
1. Connect one end of the mini-jack on your iPod headphone
jack. Once done, set your iPod or on your dashboard or your car seat so that it
will not tip over while driving.
2. Find your sound system's auxiliary input Pioneer. It is
often located in front of the front panel stereo, but can also open the front
or back of the unit completely. If the extra connector on the back of the
stereo itself, then you remove the panel. When it comes to this, see the
instructions that came with your sound system is provided for further guidance.
3. Connect the other end of the cable mini-jack for stereo
aux port. This will allow your iPod to the audio signal through the cable to
the stereo and the stereo signal will pass to the car speakers. Most often,
when something is plugged into the stereo aux jack will work in stereo. In some
models a setting to select the additional connection. Whatever the case, now
you can sit and enjoy your iPod for that long car ride.
