Tip & How-To about Apple iPod touch
The superior audio quality thanks to the Kenwood stereo
system is as good as any on the market. However, many of Kenwood audio receivers
contain no iPod connection port. Even the business hubs of high-end
entertainment that interface with the computer via USB cannot provide
connectivity to an iPod. But that does not mean you cannot high-quality audio
through your stereo Kenwood iPod.
1. Put your Kenwood stereo. Connect devices with the stereo
turned on may lead to spikes in volume that can damage the speakers and even
your ears. Turn up the stereo, so you can use the set of connectors on the back
to see.
2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the
headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy
one of the sound equipment stores or electronics stores like Radio Shack.
3. Connect the RCA end to your cable 3.5mm to RCA in an
available port on the back of your Kenwood stereo. Put your Kenwood stereo, so
you can access the buttons on the front. Turn the sound and select the channel
of your iPod is connected.
4. Test the connection. Lower the volume on the Kenwood
stereo and start a track playing on your iPod that you can recognize. Turn your
volume until you play the iPod through the stereo to listen. If you hear no
sound, check the "Monitor CD2/TAPE2" is active, and "Mute"
is off
