20 Most Recent
Tissot PRS 516 T91142651 Wrist Watch Questions & Answers
I wanna know what use have the small screens from
I have examined their web site and found the nearest model to yours.
If you go to "http://support.tissot.ch/?mod_flashPDF/id_144/familyName_PRS%20516%20Chrono/search_T91142", you should arrive at a page which has a download in the top right.
Download this file.
Can't find any information corresponding to this
Tissot is not one of the easiest site to interrogate!
If you go into the "collections" choose any watch to get all its details on screen, at the bottom of the information you will see a search box (why isn't it on the first page I hear you ask!).
Put PRS 516 into this and you will be presented with a row of watches (that row of dots can be used to move along the row).
When you find the one that looks like yours click on the picture and the details of the watch will appear and near the bottom will be "user manual" click on this.
Good luck.
Timex t28842
the small hand is the second hand the large one is for chronograph
I am trying to reset
SET TIME:
1. Activate Crystal
2. Tap center of screen until digital time comes up
3. Press and hold top button (+) until watch beeps, display will be flashing
4. Use + and – key to adjust time. If several hours off, hold appropriate key and
after first hour passes, only the hour hand will move.
5. Make sure the digital display shows A or P for AM or PM
6. When finished, touch center of screen again.
SET DATE:
1. Activate Crystal
2. Tap center of screen until date appears
3. Press and hold top + button until watch beeps and display flashes.
4. Use + and – buttons to change date to correct one.
5. Make sure to set time first, if you set date first, you run the risk of the date
changing at noon rather than midnight.
Second hand does not go clockwise
It seems like the subdial gear wheel is jammed. You wont be able to do it yourself as the movement must be dismantled.
Look for decent watchmaker.
Tissot PRS 516
Your Tissot watch is a chronograph. The large second hand is for the stop watch only. There is another second hand by the six that is for the time. To get the large second hand to move hit the top right button, that works the stop watch. If you already knew this and your large second hand is not going around then there is something wrong with the watch either a battery or needs service.
How to set moon phase on tissot pr100
for Tissot PR100 Automatic Chronograph with moonphase, minute recorder, hour recorder and seconds subdials, to set the moonphase
there is a sunken button between the chronograph start/stop and the winding crown.
Using a pointed object such as a ballpoint pen, push the sunken pusher gently until the moonphase moves one step, (if you press the pusher completely in, it will also advance the calendar hand, so only press enough to move the moonphase and no more for moonphase adjustment)
