20 Most Recent Traxxas 4910 T-Maxx RC Monster Truck Questions & Answers
I took my traxxas t maxx 2.5 to the beach and
Firstly the engine could have breathed in some sand from the beach thus causing the lack of power , it could also be that the glow plug requires changing too, this is a common problem on nitro cars, especially when the engine gets too hot and doesnt get much cooling. Reset to factory settings on the carb(see your manual or download one) then restart , also make sure you are using the correct fuel , it must be 20% nitro. Lastly for the replacement from 2.5 to 3.3 yes you can do it . all you have to do is unbolt the old 2.5 replace with the 3.3 plumb in and wire is as before , check the messing on the spur gear. though be cautious not to over rev the engine as you will strip the spur gear.
5/8/2017 8:17:46 PM • Traxxas 4910... • Answered on May 08, 2017
2answers
My truck is spitting fuel out of the exhaust and
yes it is to cold you have to turn down the fuel mix its running to rich
10/10/2012 2:14:41 AM • Traxxas 4910... • Answered on Oct 10, 2012
Traxxas 2.5 is overheating
wow, 315 degrees is way too hot. one way to fix that is to turn the high speed needle out 4 1/2 turns from all the way in. this will help fix the stalling problem and the heat.
4/6/2012 2:16:15 AM • Traxxas 4910... • Answered on Apr 06, 2012
My traxxas motor looses power after running for awhile
this happens to mine sometimes too. i have found that if you richen the high speed needle about a 1/4 turn it works fine. it will also keep your engine temp. down.
4/6/2012 2:13:53 AM • Traxxas 4910... • Answered on Apr 06, 2012
2answers
Traxxas 2.5 just got it
you can find the factory settings at traxxas.com
4/6/2012 2:11:16 AM • Traxxas 4910... • Answered on Apr 06, 2012
I have a T-Maxx pro.15 truck. the transmission is
I would probably open up your gear box on the back near the motor and check to make sure that the gears are not stripped and that there are no slips
10/14/2011 9:16:41 PM • Traxxas 4910... • Answered on Oct 14, 2011
0answers
When i push my t-maxx 2.5 to the ground the back
cheak ur shocks, may need to add a some tensioner clips to the front shocks to streangthin the spring. also cheak the fluid, u may need to change it, Also there is 4 different positions to put the bottom screw of the shocks into, The closer to the chasie, the stronger the recoil should be, and visa vers.....
3/5/2011 4:05:13 AM • Traxxas 4910... • Answered on Mar 05, 2011
0answers
2answers
I got a traxxas t-maxx 2.5 for christmas, most of
http://traxxas.com/pdfs/4910_manual_2003.pdf
1/11/2011 9:32:43 PM • Traxxas 4910... • Answered on Jan 11, 2011
My tmaxx for some reason will not move it runs
Is the spur gear missing teeth?
1/3/2011 11:22:09 PM • Traxxas 4910... • Answered on Jan 03, 2011
Need a manual or something
There are actually 3 screws on the carb. The big one is the most important, it adjust the high speed fuel mixture. A good starting point is 2 1/2 turns out from fully seated. There is a small screw which is located right next to the air intake. This is the idle stop and should be set so that the engine idles smoothly. The third screw is located on the side. It is also small and it controls the idle fuel mixture. A good starting point for the idle fuel mixture screw is 1 3/4 turns out from fully seated.
12/31/2010 6:41:35 AM • Traxxas 4910... • Answered on Dec 31, 2010
Chassis replacent
There are no books or manuals telling you the best step by step, but I can tell you that it is not to difficult. I suggest starting with the front gear box, and just make your way back, swapping part for part if you are unsure. Hope this helps
5/15/2010 3:21:30 PM • Traxxas 4910... • Answered on May 15, 2010
I bought an older t maxx 2.5 was running great
Hi
The plug could be fouled. The gas could be contaminated, there could be an air leak in the tank or the lines, the carb filter could be dirty or the last time you ran it the engine sucked in a bunch of dirt. I would start by cleaning the the car completely. Hobbytown USA makes a cleaner which cleans off all the gunk and is water soluble so after you spray it down to loosen the dirt you can hit it with a high pressure hose. Now, replace the plug and carb filter. Drain the tank and tubing. Just the tank for air leaks. Just disconnect the engine gas inlet, tap off the pressure line and then blow into the tank. The pressure should stay constant. If not replace. Now refill the tank, change the plug and make sure there is no dirt stuck in the muffler. It should start easily at this point. If not, then there is probably an air leak in the carb or there excessive dirt in the engine. They would require a strip down next. Most hobby store will do all this for you. Hobbytown USA really seems to know what they're doing. Good luck
3/29/2010 5:50:22 PM • Traxxas 4910... • Answered on Mar 29, 2010
Traxxas Owners Manual T-Maxx
You can get them from Traxxas directly. I think that you may be able to download them from their website.
12/24/2009 2:25:38 AM • Traxxas 4910... • Answered on Dec 24, 2009
I just bought a t-maxx off of ebay, didn't come
The red thumbswitch on the transmitter controls the forward/reverse servo. With the body off of the truck, flip the switch up and down and see if the servo is moving. The servo moves a linkage back and forth in the transmission. This linkage could be out of adjustment. If the servo is not moving remove the receiver box and make sure that the servo is plugged into the receiver. Manuals are available from Traxxas, you can check on their website. You might even be able to download a copy from the web site. If not you can purchase a hard copy from them.
12/9/2009 9:47:37 PM • Traxxas 4910... • Answered on Dec 09, 2009
My t maxx 2.5 is driving and steering by itself.
Sounds like an antenna problem. Make sure the antenna is isolated from any metal of the chassis or engine. Also make sure the antenna is not damaged anywhere. You could try purchasing crystals on a different frequency, but I think that it is more likely a mechanical issue.
12/9/2009 9:38:09 PM • Traxxas 4910... • Answered on Dec 09, 2009
Spur gear is giving me problems
two things can be happening 1. you mother mount is moving 2. the the chasis is flexing too much. most likley the first one. try using some loctite on the screws that hold the motor mount.
7/7/2009 3:07:19 PM • Traxxas 4910... • Answered on Jul 07, 2009
Rapitly Blinking green light at the VXL-3s on my traxxas Slash 4x4
call traxxas. they can help.might hold down butn. plug bat in then try to program.
4/24/2019 1:13:18 AM • Traxxas Toys • Answered on Apr 24, 2019
Traxxas 4910 T-Maxx RC Monster Truck Logo
30 questions posted
Top Traxxas Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
View Most Popular
Traxxas Toys
  • Traxxas Toys
Most Popular Question
traxxas 2 5 just got
  • Toys
