20 Most Recent
Traxxas T Maxx 3.3 Monster Truck Questions & Answers
Starts but wont stay running
how new is the truck...if its still brand new the motor usally needs a break in time or a rich fuel so that the piston and sleeve seat properly...or if it was run too lean for too long the sleeve needs replaced...or carb settings we will work through what we can..to get it going..
T-Maxx 3.3 wont drive
Sounds like an internal gear problem with the transmission. I would remove the transmission and open it up, anything that is broken will be easy to spot. All of the parts are available at a local hobby shop or from Traxxas directly.
Won't run
i had one of these, and it is easy to blow the motor, I was very careful when breaking it in when new, it really hauled, my friend also bought one, he was not so careful (wanted to race it right away) and he blew his engine, it started doing the same things you describe, he sold his to me, I rebuilt engime, it ran good as new until the day I sold it. you can purchase a new cylinder, crank, & piston at hobby town last I knew
My Traxxas T Max 3.3 engine starts but my truck
i just had this problem with my tmaxx 3.3,was driving it and heard a pop and no more drive,would justroll a bit at a time while the rpms were racing higher and higher.looked at everything and looked fine.took the transmission apart and looked fine also.tried to hold the spur gear to see if it was strong with turning the tires,could feel a slip with it as i turned it,there is a pin that holds the gear to the shaft and it broke inside the gear replaced all is good now,happy racing
