20 Most Recent
AT&T Spirit 6-Button Stard Misty Phone Questions & Answers
I have 2 incoming lines,
A Busy signal usually indicates a "Short" circuit across the Telco line somehow.
The phone indicates to the exchange that it is being used by placing a "1000 OHM Resistance" across the line, Tip & Ring..
If a phone will NOT hang up, then usually this means that there is still a resistance across the line even when hung up, this can be a fault, in the Telco, Cable to the phone, a wiring fault, after the point of entry, or an internal fault in the actual phone itself. One must isolate the actual issue.
Get you line checked by your Telco.
Check your Phone Jack.
Check your internal wiring
Check your phone itself.
Check to see if a normal phone will work directly across the line...
I have an AT&T Spirit
Have you try to reset it? If no, Just try to reset it to factory settings.
Remove the AC Adapter from the AC power (either at the base or at the
wall outlet) and immediately connect it again. Remove battery from the handset and immediately replace it. Place the
handset back into the charger for about 5 seconds. That should reset the phone and put the phone on default.
Take care.
Message and Intercom wont turn off!
Unfortunately, you cannot turn off the intercom or message waiting features. When trying to turn off the message waiting light, are you pressing the intercom key and entering # then 6?
There are to many programs
I paid over $100.00 for this phone. It's still not right/ I'm not gonna pay Panasonic any more. I know you only represent them. no reason to write back. sorry
There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone?
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom,
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the
appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
AT&T Spirit Phone
From station 10 press intercom, Press speaker, Dial *0, Dial 1, Then Press Ftr 7.
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
How to register AT&T Synj SB67108 to new base unit SB67138?
Register SynJ SB67108 Handset
To register an AT&T SynJ SB67108 handset to a new SB67138 base unit, you will need to follow these steps:
- Make sure the new base unit is plugged in and turned on.
- Press and hold the "Menu" button on the handset until the display shows "Menu."
- Use the navigation buttons to select "Registration" and press "Select."
- Select "Base" and press "Select."
- The handset will begin searching for the new base unit.
- Once the base unit is found, it will be displayed on the handset's screen.
- Select the new base unit and press "Select" to complete the registration process.
- The handset should now be registered with the new base unit.
Note: if you have multiple handset you need to register, repeat step 2-7 with each handset.
