20 Most Recent
E Sky Flight Simulator Training Kit Questions & Answers
Esky simulator 905A donwnload driver
this is the 5 Driver Finder (Online) :1. http://www.all-driver.com- Search for all aviable Driver2. http://devid.info-
Search Driver From Hardware ID (you can See Hardware ID from Computer
Management > Device Manager > Propeties hardware you've Need the
driver > Details3. http://www.driverguide.com- Search Driver by Model Name or number4. http://www.driverstock.com- Search Driver by type and the producer5. http://www.nodevice.com-Seacrh driver from Categories or Companiestry it,and don't forget to rate me if this post helpfull.thanks be4
E-sky 4 ch simulater is not working on w vista, d3drm.dll Error
To download the FMS flight sim go to this
site http://n.ethz.ch/student/mmoeller/fms/index_e.html
With windowsXP and earlier it will work fine.
BUT If you use vista you will need to also add this file to your computer "d3drm.dll"
go to http://www.driverskit.net/dll/get/494.html to download the file. Then put it in your
C:\Windows\System32 folder on your computer. It wont work until you do this. Good luck.
Will not launch after installation.
Some users running Windows Windows 7 or Vista are experiencing problems with the FMS program. When the program is launched the following error message is displayed "D3DRM.DLL is not loaded"
D3DRM.DLL is Direct3D Retained Mode, an older graphics display technology from 1997 that was removed from Windows 7 and Vista.
The good news is that it's a pretty simple procedure to get it put back into Vista. The CD that we included has the newest stable version of FMS (Version 2.0 Beta 7). So just install that from the installer CD as you normally would following the on screen instructions. If you have already installed it, read on - there is no need to re-install it.
You can the D3DRM.DLL from this link:
http://www.microflight.com/img/d3drm.zip;jsessionid=pvQhMmWKCyv7GXG4vTYLYlWBTxRHQYlxZp8bXQ1rhBnTNMRTYpswB4kTQbsW4VSqygvyKjncmPD6T4S4NJK2F0X7Xp6PnV2VKryTVC1kdTxYHL3djKJknnJWnMDhqQh7!-733962811
Now you will need to download the D3DRM.DLL. Open the Zip file and then copy D3DRM.DLL to the FMS directory. By default your FMS directory will be located C:\Program Files\FMS\
The easiest way to do this is to double click on the d3drm.zip file, it will open a small window with d3drm.dll in it. This is the file we have to copy - just keep this window open for now.
Next click "start", then "run". Now type "c:" without the quotes, and press enter. It will open the Explorer application, in the right pane you should see Program Files, Double click on it. Then you should see FMS, Double click on it. This is where you need to copy d3drm.dll
To copy the file simply drag and drop the d3drm.dll from the window we left open before to the FMS directory, be sure to drop it in a empty white area and not on another folder inside that window.
That's it, FMS should run perfectly now.
Have the new belt cp 1 and constant enthusiasm in
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I running windows 7 and I orderd the E-sky flight
Try checking if the manufacturer has a web site. (I could only find sites that were selling the product.) Otherwise, this seems to have drivers for XP and before. You can try running the installer and other programs in the XP compatability mode. (Right click on the exe and choose Properties, then select the Compatability tab. Check the box for Run program in compatability mode and select XP from the drop-down menu). Then right click on the installer again and choose Run as Administrator.
If you have Windows 7 Pro or Ultimate, there is another work-around. Download and install the two programs that create Microsoft's XP mode. Install the device in the virtual XP computer that is now on your computer. (You no longer need a CPU that handles virtualization to do this.)
I hope this helps.
