20 Most Recent
Volvo s60 cd magazine. cd changer 10 cd for 9488925.; cd changer Questions & Answers
Can u get the code off the serial no on the radio
If the Volvo dealer cannot supply your code then your only option now is to remove it from the dashboard and take it into a Decoding Service.(or your local Car Radio / Audio Store )
They will connect it up to a laptop and electronically read / recode the security memory chip (EEPROM)
I need code radio for my volvo s40 serial no : V03920 3261E065
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio. The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Volvo servicecentre and get them to enter this code for you.
No AM radio on my 2008 XC70
If it was me i would go to a car radio shop and purchase a new and cheaper radio including installation. It would be a lot cheaper than $850.
I need the Radio Code for 2000 year Volvo S40 XS
Need code for my car
make: volvo
model: s70
CD player says Cd Error
What you might want to try is to run a CD player cleaner disc through it; if it is a problem caused by a dirty head or pickup, this sometimes helps. CD cleaner discs are available at Wal-mart or any electronics store.
If this does not help, the CD player will need to be sent to service center
My raido keep off even when I trun it on off apper
concerningmVC 602 radio. proceed as follows I have used my own numbers here, subsVOLVO RADIO CODE 5063
5063
COD enter I, 0 appears, press > to 5
enter 1, 0 appears
enter 1, 0 appears, press > to 6
enter 1, 0 appears, press > to 3
enter 1
substitute your own
Volvo XC90 2005 model. The
Follow this...
1 Sit in the driver's seat. Pull the gear shifter in the center console as far back as possible. Pull the trim ring around the shifter back toward the rear seat, then push it toward the driver's side seat. Pull it out of the console and set to the side.
2 Use the flathead screwdriver to unscrew the two screws underneath the climate controls, revealed by removing that center console trim. Pull the climate control and radio assembly toward you to release it from the dashboard. Twist the assembly to the side and unplug the wiring harnesses.
3 Unscrew the radio from the bracket securing it to the assembly. Pull down the clips holding it to the assembly.
I suggtes check
THIS LINK for aditional details:
How to remove a Volvo XC90 car stereo - (2005 Onwards)Hope this helps.
Hello there just got a volvo c70 and the radio
Disconnect the car battery for 10 minutes then try. But if d
isconnecting the battery did not make any difference to it, then your car radio is on a lockout mode and it needs to be left up to one hour with the radio switched ON either in the car (with the ignition on or out on a power supply) it will then reset and allow you to put the correct code in. if the display reads "OFF", then the radio is locked and needs to be reset.
After entering the code 3 times ... the radio displays "SYSTEM OFF"...
A few hours latter, the system resets itself and again displays "CODE"
and allows for 3 additional trys...
Thanks.
keep updated for any more query.you can rate this solution and show your
appreciation.
All displays work on Volvo SC-805 but there is no
I could make some guesses but hate to assume
what year is your vehicle, what trans, what engine and what audio system, base or deluxe?
it all makes a difference as I look up all the wiring diagrams
