20 Most Recent
AT&T 944 Four Line Intercom Phone Questions & Answers
It keeps on beeping
This happened to me today!
Do the following in order:
1.take battery out of back of phone
2. unplug all phone lines from phone, then unplug all phone lines from wall
3. unplug ac from phone, then from wall
Wait 30 seconds.
In this order:
1. replace battery
2. replace phone line(s) to phone, then to wall
3. replace ac to phone, then to wall.
These steps solved it for me! Good luck.
How do i set the intercome on a speakerphone 944
Assign an Extension Number to Your Phone
1 Press program.
2 Press down arrow until the screen displays EXTENSION NO, then press right arrow.
3 Press the up arrow or the down arrow to select the desired extension number (from 11 to 22).
4 Press save store your selection.
NOTE: If you duplicate an extension number, you will hear a repeating
short ring. Repeat Steps 1-4 and assign a different number (from 11 to 22).
Phones will not release hold when picking up on a different phone
Make sure you have filters on the lines between your DSL and your phones. Use the line out from the back of your modem to split to your phones if you don't have any filters. You may have to take line 2 from the back of the DSL modem to send to all of the phones. This is usually a filtered source and should isolate your phones from the DSL. Put the filter on any other devices that are sharing line 2 too, fax, computer, credit card machine etc.
Intercom / page problem with AT&T phones model 944 and 955
Do you have DSL on this line? Make sure you have filters on the lines going to the phones or take the line coming out of your DSL modem and split it to the phones.
Also, try unplugging your fax, computer modem or credit card machine and test the intercom. Sharing one line for several devices can make the intercom unhappy.
Hooked up old phone we weren't using. When I plug
Sounds like you'll need to setup the intercom number again.
1 Press program.
2 Press the down arrow until the screen displays EXTENSION NO, then press the right arrow.
3 Press the down arrow or the up arrow to select the desired extension number (from 11 to 22).
4 Press the save button to store your selection.
Voicemail
No. The voicemail is through the phone company
How to register AT&T Synj SB67108 to new base unit SB67138?
Register SynJ SB67108 Handset
To register an AT&T SynJ SB67108 handset to a new SB67138 base unit, you will need to follow these steps:
- Make sure the new base unit is plugged in and turned on.
- Press and hold the "Menu" button on the handset until the display shows "Menu."
- Use the navigation buttons to select "Registration" and press "Select."
- Select "Base" and press "Select."
- The handset will begin searching for the new base unit.
- Once the base unit is found, it will be displayed on the handset's screen.
- Select the new base unit and press "Select" to complete the registration process.
- The handset should now be registered with the new base unit.
Note: if you have multiple handset you need to register, repeat step 2-7 with each handset.
