20 Most Recent
Acura 2004 MDX Touring with Navigation S Questions & Answers
My acura tl 2000 bose stereo has problems playing
Most likely your CD laser is either misaligned after 17 years of driving on the roads, or it's still dirty inside. Maybe a combination of both. Those aftermarket lens cleaners hardly do anything and sometimes make the situation worse. Your best best is to find out the price to have the unit serviced, or find a deal on a refurbished one online. Another option is to get an aftermarket radio and an adapter so it can safely feed the Bose factory amps. The final (and most expensive) option is to not only buy an aftermarket radio, but also bypass the factory amps altogether, using the new radio's built in amp, but then you will also have to replace the speakers as well. The Bose components are engineered to all work together and don't perform properly when mixed with aftermarket components. I would only suggest this when your factory speakers or amplifier starts to fail, because it can sometimes get quite expensive to replace Bose speakers, and especially the amplifier. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/reginald_bec291de192ca44f
Lost car radio code for peugot 306 vin number vf37akfwf33226136
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio. The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Peugot service centre and get them to enter this code for you.
How can i get the
If you can provide the necessary information then your ACURAcode is available here for free
https://radio-navicode.acura.com/?src=inq
If not then the code will only be available from your localHonda Dealer or a Decoding Service ...who will plug in a laptop to read/recodeyour memory chip (EEPROM)
Useful ACURA/HONDA Contacts
TELEPHONE NUMBERS
Honda UK 0845 200 8000
Honda USA 1-800-999-1009 (Toll Free)
Honda Canada1-800-387-5399 (Toll Free)
Honda Aus 1800 804 954 (Toll Free)
Honda NZ 0800 2 46632 (Toll Free )
Radio unlock code for Acura 1999 3.2 TL
there is no site or organization willing to give you a stereo code for free. Some amount of money will be charged in exchange for the radio code.
Radio unlock code can be gotten from the below link:
http://www.radio-code.com/
Also the process to follow in order to successfully unlock the stereo is stated in the link.
In addition this link claims to generate stereo unlock codes for free, you can give it a trail as it might work for you.
http://www.shouldpay.co.uk/free-radio-unlock-codes.html
Good luck.
My car hesiyating like it
This could be a lot of things. If the check engine light is on then take it to Autozone and have them run diagnostics for free. This will give you an idea of what could be causing this. If the check engine light is not on, then try changing the fuel pump, spark plugs and plug wires.
2002 Acura RL radio code
This code is only available from your Main Dealer or a Radio Decoding
service
Will not be available for free from anywhere on the Internet
