20 Most Recent Lionel New York Central Flyer Questions & Answers
There is no power to
Try unplugging the transformer for 5 minutes,then plugging back in.Do not just turn off power.Sometimes transformers will lock up and need to be reset.If this does not solve it,please do not approve/disapprove this yet as it will cut off our link,unless your problem is solved 100%.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg
6/16/2014 4:49:42 PM • Lionel New York... • Answered on Jun 16, 2014
Lionel instructions
Whic transformer?
5/6/2014 5:07:42 PM • Lionel New York... • Answered on May 06, 2014
Lionel # 3830 submarine instructions for assembly
You can download instructions and product manuals at Lionel.com in their customer service section. If you don't find what you need, use the Contact Us link to ask for help. Lionel offers great customer support.
5/6/2014 4:49:38 PM • Lionel New York... • Answered on May 06, 2014
Lionel 6-5960 sound activation instructions
Contact Lionel Customer Service: 586-949-4100
3/6/2014 5:00:06 PM • Lionel New York... • Answered on Mar 06, 2014
Car will only go in one direction
please provide more information: control system used. locomotive or set number
2/9/2014 12:35:52 PM • Lionel New York... • Answered on Feb 09, 2014
Purchased a Lionel New York
The magnet may not have enough punch using track power. Recommend you use an aux power source fixed 10 to 13VAC supply and not track power. There may also be a slight + difference between the track magnet head and the plate on the coal car so that there is insufficient force to release the dump mechanism.
9/5/2011 1:20:13 AM • Lionel New York... • Answered on Sep 05, 2011
Lionel 313 bascule bridge
It sounds like the counterbalance spring is loose or disconnected. I would rather add weight to the counterweight box to take some load off of the motor...Use fishing sinkers, one or two rolls of pennies or equivalent. Also do not overtighten the spring you will warp the base of the bridge.
9/12/2019 1:20:27 PM • Lionel Crafts &... • Answered on Sep 12, 2019
I just got a postwar
http://www.ebay.ca/itm/Lionel-Drive-Belts-2-NEW-3540-3512-3545-Radar-Car-Fire-Car-TV-Car-W-Insts/122742995541?hash=item1c940d7a55:g:xhMAAOSwEzxYXAQs
10/25/2017 6:50:54 PM • Lionel Crafts &... • Answered on Oct 25, 2017
Lionel 3656 parts
see page 11 of attached pdf for operating instructions: http://www.slsprr.net/history/1954LionelTrainsAccess.pdf Brasseur Electric Train's, parts for 3656: Lionel 27 Parts
10/22/2014 4:31:21 AM • Lionel Crafts &... • Answered on Oct 22, 2014
Lionel toys
see attached pdf.
10/15/2014 5:02:47 AM • Lionel Crafts &... • Answered on Oct 15, 2014
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories. compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track. if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track. http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
10/15/2014 4:57:05 AM • Lionel Crafts &... • Answered on Oct 15, 2014
Lionel instructions
10/15/2014 4:42:16 AM • Lionel Crafts &... • Answered on Oct 15, 2014
Need manual or instructions or lionel wabash cannonball 70-1962-202
You should be able to get a manual from the Lionel Service Department on 586 949 4100 or use their website contact service. Contact Lionel Trains
1/21/2014 10:36:48 PM • Lionel Crafts &... • Answered on Jan 21, 2014
2answers
I am thinking of making a scrapbook for my sisters baby shower but I have no idea where to start. Any suggestions?
Scrapbooking is a wonderful way of giving your sister a real personal memory of this special time. Check out this Daily Motion video for an idea to get you started, http://www.dailymotion.com/video/xffl74_how-to-make-a-functional-baby-shower-scrapbook_school
4/24/2024 5:18:30 PM • Crafts & Hobbies • Answered 14 hours ago
I want to make a necklace for my sons wedding with pearls but they are so small and delicate I am not sure what thread will work with it?
Pearls often have very small holes. You need to use a natural silk thread or another very fine thread. It really depends if you plan to knot between pearls, if so that will affect your choice of thread, so make sure you get advice from a beading expert before you buy.
4/7/2024 2:22:50 AM • Crafts & Hobbies • Answered on Apr 07, 2024
Are there soap making kits that are good for kids?
Amazon have a good soap making kit for kids but if your kids are young you should make sure that you supervise the hot parts as it can be quite dangerous.
http://www.amazon.com/Cool-Kids-Soap-Kit/dp/B00124WCJ0
3/18/2024 9:18:03 AM • Crafts & Hobbies • Answered on Mar 18, 2024
2answers
My cricut explore air 2 will not load my mat, what could be the problem?
Cricut Explore Air 2 helps in cutting the beautifully intricate designs using the compatible cutting machines. However, in some situations, you can get the problem where you will not able to use the mat. In this situation, you first make sure you are following the right guide to load the mat, check if the mat is compatible with your Explore Air 2 machine, or your device is not facing any problem. To get rid of this issue, you have to reset all of your devices and set up the machine once again. Also, check if the mat is not damaged, refer to the Cricut crafting guide for using the mat, use the compatible mat, and more. You can also connect to the Cricut customer support team to get more info from professionals to resolve the issue. cricut explore air 2-ibihixnmadozsxrjeznrdibm-d-1.png
3/11/2024 12:35:42 PM • Crafts & Hobbies • Answered on Mar 11, 2024
Constraints about making a Jaws of Life model with cardboard, split pins, syringes and plastic tubing.
Question edited for clarity, otherwise this question makes no sense. I presume you mean a MODEL of the Jaws of Life. Large capacity syringe powering a small capacity syringe with give a significant pressure advantage. The only issue I can think of is the the friction of the secondary piston may be too sticky on the wall of the smaller syringe but if you fill the system with water, you will get true hydraulic results because air can be compressed but water can't ...
2/22/2024 5:52:45 PM • Crafts & Hobbies • Answered on Feb 22, 2024
tip
Crafting Clear and Effective Troubleshooting Guides: A Handy Guide for DIY...
Are you tired of scratching your head over malfunctioning gadgets or appliances? Fear not! With a well-crafted troubleshooting guide, you can conquer technical challenges like a pro. Here are some expert tips to help you write troubleshooting guides that shine:
  1. Know Your Audience: Understand who will be using your troubleshooting guide. Are they beginners, enthusiasts, or experts? Tailor your language and level of detail accordingly to ensure accessibility and effectiveness.
  2. Start with the Basics: Begin your guide with an overview of the problem and its potential causes. Break down complex issues into simple, easy-to-understand steps. Remember, clarity is key!
  3. Step-by-Step Solutions: Provide clear, concise instructions for each troubleshooting step. Use numbered lists or bullet points to outline the sequence of actions users should take. Include relevant images or diagrams to enhance understanding.
  4. Use Descriptive Language: Describe symptoms, error messages, and actions in detail. Avoid jargon or technical terms that might confuse readers. If necessary, define unfamiliar terms or provide a glossary for reference.
  5. Highlight Common Pitfalls: Anticipate common mistakes or misconceptions users might encounter. Address these pitfalls proactively to prevent frustration and ensure a smoother troubleshooting experience.
  6. Include Troubleshooting Tips: Offer troubleshooting tips or tricks to expedite problem-solving. Share insights or shortcuts that can help users navigate tricky situations with ease.
  7. Test and Revise: Put your troubleshooting guide to the test! Walk through the steps yourself to identify any ambiguities or gaps in instructions. Solicit feedback from users to refine and improve your guide over time.
  8. Update Regularly: Technology evolves rapidly, so it's essential to keep your troubleshooting guide up-to-date. Stay informed about new developments, software updates, or common issues reported by users. Update your guide accordingly to ensure its relevance and accuracy.
Remember, writing an effective troubleshooting guide is as much an art as it is a science. By following these tips and putting yourself in the shoes of your audience, you can create guides that empower users to tackle technical challenges with confidence. Happy troubleshooting!
on Feb 17, 2024 • Crafts & Hobbies
I need 4 springs for under blades for a pro tech cs6007 contrator series planer
you can find replacement blades (also known as knives) made from a special V2 alloy (high-speed steel) on the MyWoodcutters website. Each set includes 3 HSS blades specifically designed for the CS 6007 model. The cost for a set of 3 blades is $61.50 to replace the springs for the under blades, I recommend checking with a local hardware store or contacting ProTech directly to inquire about availability.. For other parts or accessories, consider exploring online marketplaces like eBay.
2/12/2024 3:32:30 AM • Crafts & Hobbies • Answered on Feb 12, 2024
Lionel New York Central Flyer Logo
24 questions posted
Top Lionel Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
View Most Popular
  • Lionel Crafts & Hobbies
Most Popular Question
lionel 3830 submarine instructions
  • Crafts & Hobbies
