20 Most Recent
New Bright Small Holiday Express Train Questions & Answers
Each yr my New Bright Holiday Express train gets
check the electrical current to the trans former , then check the out put from transformer, may not be getting adequate electricity flow to operate , and if you continue to operate under required current , it may damage engine and or transformer , gd luck
Holiday Express Train Set
We struggled with this just today...finally figured out that you have to twist the small piece right behind the bell on the top of the locomotive.
Holiday express animated train set no.387 was given to me and I have not instructions or track lay-out? HELP
The track layout is simple enough,there are 12 straight peice of tracks and 12 curved tracks. So you can make it one big circle and not use the straight tracks or add 1-6 on each sidewith straight track and you'll have a long oval. Or have 1-4 on each side then add 1-4 after the third curved track of each circlular end to have a big type oval style.Some lites lite up right when you push the power switch on and the remaining lights will work once the train is in motion.
I have a New Bright
I think I'd get one of those chargers that will fit anything- select the right plug and voltage, you're in.
eBay is where I'd check first.
lp
I have a Large scale
yes just look at the boot sales or flea markets ,find a 9v charger with correct end on ,or visit the local chinese emporium and no b?doubt you will find a charger in their of 9v its a fairly common voltage ,9.6?? well 9v will do it fine ,or even a 12v one but dont leave it connected for any length of time
I am looking for a
If the antenna came off of the controller in one day, I would return the whole unit to where you bought it and exchange it for a new unit.
