20 Most Recent
New Bright 181 Toy Christmas Train Questions & Answers
Engine not working
Check fuel...then check radiator... Then check spark plug... At last go to service station...
Locomotive won't come on
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
I have a holiday train
The batteries go in the first car following the lokomotive, the coal tender. There is a small black knob with a ****. Turn it, and it will open the top part, so you can put the batteries in. This train set will not take a rechargeable battery. Bummer...
New instructions for new brite
You can download and print the instruction manual in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Download Adobe Reader Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
An electricalroblem with Holiday Express train
I bought a new brighton toy christmas train set at
If says 187 on the box, check out this solution:
New Bright Model #183 - how do I make the train
