20 Most Recent
RC Remote Control Rc Mini Helicopter Questions & Answers
Hi ihave brought helicopter ftw 730 but the remote
Unfortunately you can't. You will need to change the receiver or the transmitter so they are both the same frequency range eg 40mhz or 27mhz. Then you will need to check the crystal is the same frequency for the Transmitter and receiver eg 40.25mhz. NB. you can't put a 27mhz crystal into a 40mhz set or vise versa it won't work.
9/10/2009 9:27:34 AM •
RC Remote...
Answered
on Sep 10, 2009
Yale diesel fork lift forward tilt not working back tilt fine
Other hydraulic functions work so it won't be a lack of pressure - likely to be a control issue though not necessarily a lack of supply through the valve.
If the tilt ram is a single double-action type of ram one side must be exhausted in order to move when pressure is applied to the other end.
If the oil can't be exhausted from the lazy end it won't matter how much pressure is applied to the other end.
2/11/2018 11:33:13 PM •
RC Toys
Answered
on Feb 11, 2018
