20 Most Recent
Razor Pro Model Kick Scooter Fun Kid Exercise Toy Clear Questions & Answers
WHERE CAN I GET DEMINSIONS FOR A PRO RAZOR
Item dimensions are 25.5′ x 4′ x 7.25′ - Weight 8lbs.
- Razor Pro Model Scooter has a double stacked head clamp for extra head tube strength and the scooter is made from aircraft grade aluminum.
- It has a full deck and 98mm urethane wheels equipped with ABEC-5 high speed bearings.
- Razor Pro Model Scooter folds for easy storage and transport.
- It can hold riders up to 220lbs.
- Item dimensions are 25.5′ x 4′ x 7.25′ - Weight 8lbs.
I have a 24v Razor Quad. It has new batteries wired correctly, new throttle, new controller module. It turns on, but yellow light shows low power, then goes off no power to motor. What can I do next?
Question edited for clarity.
Hello again Cindy, I gave you all the information on this a few days back. You need a competently inclined person with a multimeter. The circuit is simple. You have two 12 volts batteries in series which makes 24 volts. You have a hand controller which is a variable potentiometer like a volume control, which feeds voltage to the motors. The controller module tells you the battery voltage level and probably has a couple of relays. Check the battery wiring again, you should have a wire coming in to the plus on battery 1 and the negative on battery 1 should go to the plus on battery 2. The negative wire from battery 2 completes the circuit out. Do you know your charger works? That can be checked with a meter as well.
Get out your multimeter and check the TOTAL voltage plus on battery 1 to the negative on battery 2. You should have 24 volts, 2 x 12 volt batteries in series. Take them both off and charge each one on a car charger set at 2 amps for about 4 hours each battery. Clean all the battery connectors with a wire brush and also the connectors. Smear them with Vaseline. Also make sure you have the batteries wired up correctly. If done incorrectly, you may be running on 12 volts which is why is is showing 'Low Voltage'!
https://www.google.com/search?q=razor+quad+low+power
4/9/2022 11:02:18 PM •
Razor Toys
Answered
on Apr 09, 2022
