Good Morning Randy, this is Z. Thank you for your post!
Typically error code E68 on your Frigidaire dryer can indicate one or two issues. First problem could be that one of the keys (buttons) is stuck closed (active). Enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again. If button is free but the error code still exists, the electronic control will possibly need replacing. Second issue could possibly be a current leakage to ground on heater or fuse opened. However, I would strongly suggest contacting a professional to the check the resistance of the heating element (should be approximately 14ohms) or the resistance between the ground and both heater terminals. It should be open when heater terminals are disconnected. If the readings are incorrect, then you may have a faulty heating element. Best regards!
Hi,When this happens your fans is getting the incorrect information on how to run, on some occasions both the fan and control to the fridge had to be replaced at the same time. Disconnect the evaporator fan motor and run the unit as normal. If the computer allows the compressor to run at least five mins, just replace the fan motor, if not replace both.Control board is under the unit Part# 241511102 (only if needed)Parts number for fan motor P#241509402 both of these parts should be available through your local part house or REPAIR CLINIC, to avoid shipping cost and any return issue you may have.I hope this helps, good luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
EF code on a Frigidaire refrigerator means Evaporator Fan problem. The motherboard on the FGHC2345LF can be sensing a problem with your evaporator fan. The fan could be failing so I advise that you keep an eye on the evaporator fan. All cooling will stop if this fan fails. I believe you are having two unrelated issues. The=> 241734302 Water Inlet Valveis possibly becoming defective and not allowing water to dispense. 241509402 Evaporator Fan MotorI will be here should you have questions, Thanks Sea Breeze
Did you clean the surfaces thoroughly and glue it down with white or clear silicone, then leave it to cure? also was it an OEM replacement or an Amazon special as the quality is different.
It is called short cycling. Help below
If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on.
Apr 14, 2019
JustAnswerhttps://www.justanswer.com > Appliance Repair
Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ...
1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Diane - Sorry I don't have a Frigidare but check out this site - I have heard of this but your error code could actually be 5b which is the best that they can do to show a Sabbath Day setting that the frig is designed with
Check and scroll down this website to get the description way down on the webpage:
https://removeandreplace.com/2015/08/12/frigidaire-refrigerator-error-codes/
Depends on model. Generic advice in the link and videos. You can effect a power reset by pulling that wall plug for 30 minutes.
Sabbath Mode is turned ON and OFF by pressing
and holding both the freezer "? Down" and refrigerator "? Up"
indicators for five (5) seconds. The display shows "Sb"
while in Sabbath mode
https://www.google.com/search?q=how+to+turn+off+sabbath+mode+on+frigidaire+refrigerator
The E6 error code on a Frigidaire wine fridge, specifically the model FGWC5233TS, indicates a fault with the upper temperature sensor. When this error code is displayed, it means that the temperature sensor located in the upper portion of the wine fridge is not functioning properly or is experiencing a malfunction.
To troubleshoot and resolve the E6 error code, you can try the following steps:
Unplug the wine fridge from the power source for a few minutes and then plug it back in. This may reset the error code and resolve any temporary issues.
Ensure that the wine fridge is properly leveled. Uneven positioning can affect the performance of the temperature sensor. Adjust the feet or placement of the unit to ensure it is level.
Check for any obstructions or blockages around the upper temperature sensor. Make sure there are no items blocking the sensor or disrupting its operation.
If the error persists, it is recommended to contact Frigidaire customer support or a qualified appliance technician for further assistance. They can provide specific guidance based on the model and help diagnose and repair the issue with the upper temperature sensor.
limited information ---unable to give an answer --since you need to test the unit most likely problems overheated/failing compressor [dirty/restricted air flow condenser area --condenser-evap fan fail /short--circuit short ---------breaker failing [but if tripping and resets normal usually not the case ]
Question edited for clarity.
It sounds like the compressor is struggling / overheating / failing. When was the last time your stripped the back out and removed all the fluff and debris? It overworks the compressor and gets red hot when the condenser coils get blocked. The struggling compressor causes the humming. Turn it off, keep the doors closed and vacuum it all out. Clean underneath and you might as well clean the floor and walls around it as the plan is to leave it disconnected for 1 to 2 hours to cool down and settle the refrigerant gas/liquid. Some other ideas below.
The evaporator fan motor circulates air over the coils to help keep things cool inside your fridge. If this motor starts to go bad, it will make a buzzing sound as it struggles to circulate air. You'll need to replace the evaporator fan motor to fix this problem.
Aug 22, 2022
Does ir look the same as this FRT18?
https://www.ajmadison.com/cgi-bin/ajmadison/FRT18G6JW.html
Refrigerator Capacity: 14.13 Cu. Ft.
Freezer Capacity: 4.07 Cu. Ft.
Total Capacity: 18.2 Cu. Ft.
Width: 29 5/8 Inch
Depth: 33 5/8 Inch
Depth with Door at 90°: 59 7/8 Inch
Height: 66 1/8 Inch
No. of Shelves: 2
Gallon Door Storage: Yes
Water Dispenser: No
