20 Most Recent General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane Questions & Answers
I have GXRM10RBL ge filtration installed 3 years
Insufficient water or noisy GE Reverse Osmosis Filtration System GXRM10RBL.If this sytem gets too much debris or air bubbles in it, it can cause the shut-off valve to close improperly, making an annoying whining noise and reducing water flow. By turning the wall-hung system containing the filters upside down, you can see this valve neatly wedged between the pre and post filter housings. See photo.The GE part number is WS22X10038 and can be obtained on eBay or from a supplier like ereplacementparts for about $20 including shipping.The part can be removed by gently prying it out of its retaining slot on the main housing. Be sure to note which way the valve is pointing and photograph the order of the tubes that attach to the four threaded nozzles on the valve. Use small adjustable pliers to undo and replace the plastic nuts that hold the tubes in place.This should solve the noise and improve water flow to the sink faucet.03155a57-8fe3-4355-af1d-a1511a4653c9.gif
12/30/2020 6:17:07 PM • General Electric... • Answered on Dec 30, 2020
GE reverse osmosis water filteration system is not working: No water in the tank
The tank should have only 5-10 psi when empty of water. If your unit sat for any amount of time your reverse osmosis membrane may have a problem. was all the cartridges changed? Should be yearly.
1/11/2018 12:17:58 AM • General Electric... • Answered on Jan 11, 2018
RE: R/O system.
is there a precharge of air in your tank. when empty of water th?re should be about 1 bar or 14psi of air. water must be able to empty from tank. pump air in until all water is gone. if unable to empty tank has failed. also if a pumped unit, when changing filters ensure all air is bled through pump before turning it on toprevent air locking inside pump
4/28/2017 10:06:57 PM • General Electric... • Answered on Apr 28, 2017
2answers
Im at the six month point, red light flashing, which of the filters do i replace and do i need to sanitize the storage tank?
The filters that you should replace every the six months are the two pre/post filters (FQROPF). The membrane (FQROMF) needs to be replaced every 1 to 2 years. During the filter change, bacteria could be introduced, so it is recommended that you sanitize the tank while changing the filters. Here are the filters you need to replace:http://www.freshwatersystems.com/p-7787-ge-profile-fqropf-smartwater-ro-pre-and-post-filter-set.aspx
5/30/2016 6:48:01 PM • General Electric... • Answered on May 30, 2016
I have a ge reverse osmosis filtration system and
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
www.FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
12/6/2014 4:05:24 AM • General Electric... • Answered on Dec 06, 2014
What line do you tap into to add an icemaker to a
If you want the reverse osmosis water to go to the ice maker then you tap in to the line that feeds the spiget on the sink.
11/24/2014 2:40:19 PM • General Electric... • Answered on Nov 24, 2014
Always regenerates
I believe the ratio is 5-1, so when you use 1 cup it uses 5 cups to replace that cup. The reject water will slowly run down the drain, the extra four cups.
5/29/2014 2:44:22 PM • General Electric... • Answered on May 29, 2014
How to santize the GE
UV bulb install
12/29/2013 1:05:08 AM • General Electric... • Answered on Dec 29, 2013
Tank will not fill...
wait
12/29/2013 1:02:36 AM • General Electric... • Answered on Dec 29, 2013
Ro filters going bad in 60 days
IF THE RO OR ANY T33 FILTER HAS BEEN INSTALLED HORIZONTALLY, TRY TO INSTALL IT VERTICALLY WHERE THE OUTPUT IS ON TOP. GOD BLESS.
8/15/2013 1:52:17 AM • General Electric... • Answered on Aug 15, 2013
I have a GE PROFILE R/O System with a chrome
An RO drinking water air gap faucet would be the ideal faucet to purchase for your RO system. Here are a few options you can choose from that may come in brushed nickel: http://www.freshwatersystems.com/c-821-ro-drinking-water-air-gap-faucets.aspx
6/12/2013 4:14:10 PM • General Electric... • Answered on Jun 12, 2013
Indicator lites on the GE RO facuet do not lite.
If you have concern about the quality of water being produced by your RO system, I would recommend using a handheld or in-line TDS meter. Instead of a red or green LED, these meters will give you a reading of TDS (total dissolved solids) in parts per million (PPM). With either of these meters you are taking a reading from the feed water to the system as well as from the product water, you then can calculate the percentage of solids being rejected by the RO system (using the simple equation listed below). This way you will know exactly how well the RO system is working and when the membrane needs to be replaced. I have included links below to our selection of handheld and in-line TDS meters as well as an instructional video that explains how to use a handheld TDS meter.
Here is a helpful link that includes the formula for calculating percent rejection.
http://www.freshwatersystems.com/t-measuretds.aspx
Handheld TDS Meters - http://www.freshwatersystems.com/c-253-handheld-meters.aspx
In-line - http://www.freshwatersystems.com/c-255-in-line-monitors.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
4/21/2010 6:21:45 PM • General Electric... • Answered on Apr 21, 2010
Lost manual fo model pnsf39z
You can download the complete instruction manual in PDF format by clicking this link.
For additional information, features and specifications, click here
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
4/8/2010 9:32:43 PM • General Electric... • Answered on Apr 08, 2010
Kinetico water filter leak
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What you are describing sounds like a quick connect fitting. I have included a link below to a video that explains how this type of fitting works. If you are using plastic tubing with these fittings you may be able to remove the tubing from the fitting and cut back about ½” from the end of the tubing and reinsert it into the fitting. Do not cut the tubing with scissors, use a tubing cutter or razor blade knife (see video). If that doesn’t solve the leak and you find that you need to replace any fittings we have a complete selection located here: http://www.freshwatersystems.com/c-276-fittings-valves-tubing.aspx
3/29/2010 6:50:03 PM • General Electric... • Answered on Mar 29, 2010
Lost owner's manual, I'm changing pre- and
Open faucet and let water run for 2 hours
3/8/2010 12:45:46 AM • General Electric... • Answered on Mar 08, 2010
GE smartwater R.O. system making noise from hole on side of fauce
Probably some gunk clogging the drain line. First step would be to remove the drain line from underneath the sink and check to see that it is clear. If it isn't, the next thing that may happen is when it gets completely clogged, water will start shooting out of the weep hole. As an added measure< i would say to force compressed air down the weep hole to clean out any clog in the line that you can't reach.
10/2/2009 8:13:47 PM • General Electric... • Answered on Oct 02, 2009
GE smartwater R.O. system leaking out weep hole
Same exact problem started for us last night. (Same model, installed by me about four+ years ago) Water was really coming out of the weep hole, and didn't stop until I shut it off at the valve. This happened once before, and all I had to do was clean the drain line adapter, because it gets full of gunk from the disposal over time. But this time that did not do the trick. (Plus there was not all that much gunk this time....) So I was baffled for awhile but came up with this solution.
I hooked up a small length of clear tubing to my cheap-o tire inflater/air compressor. Put the clear tube against the weep hole. Turned on the compressor, and VOILA!, a bunch of gunk that was clogging the drain tube came out. I think when this tube, or the drain line adapter gets clogged, it causes water to go out the weep hole instead of down the drain. (If you don't have a small compressor, then theoretically there is enough air pressure from something like a bicycle pump, and this solution *might* work with one of those. But if you try this, of course only use the DOWNWARD (air-going-outward) pump action...pulling up (inward) would force the clog deeper up the drain tube)
10/2/2009 8:07:58 PM • General Electric... • Answered on Oct 02, 2009
No hot water
thermocouple
2/9/2009 10:58:53 PM • General Electric... • Answered on Feb 09, 2009
My hamilton beach Top cooling Water Dispenser Model Number Tl-1-2 is not cooling water a few hours ago The motor is constantly working,however, the blue light not switched off Please advise
A few troubleshooting steps you could try: Check the Power: Ensure that the unit is properly plugged in and the circuit breaker hasn't tripped. Check the Cold Switch: There should be a cold switch on the back of the unit. Make sure it's in the ON position. Temperature Limiter: It's possible that the temperature limiter may have tripped. You can try setting the hot and cold power switches to the OFF position, wait five minutes, then set the switches to the ON position. Wait 30 minutes for the water to heat or cool. . Mineral Build-up: If the dispenser has been used for a long time, there might be a mineral build-up in the tank that could be clogging it3. You might need to clean the dispenser to remove these deposits. If none of these steps work, it might be best to contact Hamilton Beach customer service for further assistance
4/18/2024 2:03:49 PM • Water Filters &... • Answered on Apr 18, 2024
2answers
I have White particles coming out of my 5 gallon water cooler. I cleaned the cooler with the manufacturer's (Avalon) cleaning kit but the particles are still there
You may have spotted white and black flakes in water in the past. White flakes are created by mineral deposits from hard water, whereas black ones are caused by mold that develops in your water dispenser.
9/1/2023 7:54:45 PM • Water Filters &... • Answered on Sep 01, 2023
General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane Logo
Popular Tags
53 questions posted
Top General Electric Water Filters & Coolers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a General Electric Water Filter and Cooler Expert? Answer questions, earn points and help others
View Most Popular
  • General Electric Water Filters & Coolers
Most Popular Question
kinetico water filter leak
  • Water Filters & Coolers
