20 Most Recent
Saeco Odea Go Automatic Espresso Machine Questions & Answers
Why doesn't it turn on?
No power, broken wire, bad connection, blown fuse, bad heating element, bad switch, ad infinitum.
The coffee grounds lihgt and the descale light flash after I push the brew button on my seaco odea giro.
The sensor inside the water container has either mineral build-up (scale) or a bit of coffee grounds stuck to it.
- Run a cycle with a retail coffee maker "cleaner solution" to clean the water reservoir, or let vinegar soak inside 5+ hrs.
- In both cases, turn unit upside down and power wash reservoir 2X to dislodge deposits that have loosened during the soak.
- Make sure to run a few cycles of plain water thru coffee maker before making the next batch of coffee.
Steamer not working
Try this push in on the steam knob after it is turned on if that works the steam valve assembly needs to be replaced.
Saeco odea eror
Alarm light:
• permanently on (one or more events): signals the machine is out of coffee, that the water tank is empty, or the grounds drawer is full.
• on and slowly flashing (one or more events): signals that the Brew Group is not inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not inserted or the service door is open.
• on and quickly flashing : signals the need to prime the water circuit.
