20 Most Recent Cuisinart DCC-1100 12 Cup Programmable Coffeemaker Questions & Answers
How to clean coffee stains on white coffee maker
Plastic can absorb Stains, so you will need to use some kind of bleaching poduct. some products you can try individually:
  • Baking soda
  • Bleach
  • Water
  • Vinegar
  • Rubbing alcohol
Dilute with luke warm water , except for Rubbing Alcohol Use some kind of tray which you don't mind if it gets bleach stains to protect your countertop. put the device on the tray. If you can't soak an item, try disconnecting the device, then wrapping a lightly soaked hand towel or paper towel over the area that is discolored Rinse with luke warm water, and make sure device has completely dried before reconnecting.
9/9/2023 9:47:18 AM • Cuisinart DCC... • Answered on Sep 09, 2023
2answers
Why do I get so many coffee grounds in my cuisinart on demand coffee maker?
Many times this is a result of the coffee grind. To overcome this with some brands, I use an additional filter, put the desired amount of coffee in it, and then fold the sides over to make an envelope. Place the folded sides down and brew coffee. If any of the coffee gets out, the second filter should catch it.
2/2/2019 5:10:51 PM • Cuisinart DCC... • Answered on Feb 02, 2019
Can I brew coffee if the cleaning light doesn't go off?
MY FREIND IT MUCH EASYER TO JUST TO THE CLEAING FERST IT WILL TAKE YOU LESS TIME
3/15/2016 2:12:36 PM • Cuisinart DCC... • Answered on Mar 15, 2016
0answers
My coffee maker is leaking from the reserve. Is there a fix? I don't see a crack. It just started recently.
Reserves usually has a overflow hole on back . If not you might look for leaks around bottom were reserve meets up with coffee maker. Maybe leaking there.
10/29/2015 2:56:30 AM • Cuisinart DCC... • Answered on Oct 29, 2015
Coffee maker turns off too quickly
Unplug the coffee maker for half an hour, then plug it back in. This will reset the computer inside the coffeemaker and the early shutdown problem should disappear! I was told this by Cuisanart when ours began shutting off early. It works!
12/31/2014 10:28:32 PM • Cuisinart DCC... • Answered on Dec 31, 2014
Cuisinart DCC-1100 12 Cup Programmable Coffeemaker Logo
3 questions posted
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
DCC Cuisinart
  • DCC Cuisinart
Most Popular Question
get many coffee grounds in cuisinart
  • Coffee Makers & Espresso Machines
