20 Most Recent Razor A2 Folding Kick Scooter Red Questions & Answers
I have a Razor A2
I don't think a2 razor is a folding scooter.You should check it first.A3 is better than a2. The Ultimate Razor A3 Kick Scooter Review
3/8/2018 5:46:27 AM • Razor A2 Folding... • Answered on Mar 08, 2018
My razor isn't charging what can I do to make it worm
Maybe the battery inside is swollen or faulty and needs to be replaced
9/14/2022 3:09:52 AM • Razor Toys • Answered on Sep 14, 2022
I have a 24v Razor Quad. It has new batteries wired correctly, new throttle, new controller module. It turns on, but yellow light shows low power, then goes off no power to motor. What can I do next?
Question edited for clarity. Hello again Cindy, I gave you all the information on this a few days back. You need a competently inclined person with a multimeter. The circuit is simple. You have two 12 volts batteries in series which makes 24 volts. You have a hand controller which is a variable potentiometer like a volume control, which feeds voltage to the motors. The controller module tells you the battery voltage level and probably has a couple of relays. Check the battery wiring again, you should have a wire coming in to the plus on battery 1 and the negative on battery 1 should go to the plus on battery 2. The negative wire from battery 2 completes the circuit out. Do you know your charger works? That can be checked with a meter as well. Get out your multimeter and check the TOTAL voltage plus on battery 1 to the negative on battery 2. You should have 24 volts, 2 x 12 volt batteries in series. Take them both off and charge each one on a car charger set at 2 amps for about 4 hours each battery. Clean all the battery connectors with a wire brush and also the connectors. Smear them with Vaseline. Also make sure you have the batteries wired up correctly. If done incorrectly, you may be running on 12 volts which is why is is showing 'Low Voltage'! https://www.google.com/search?q=razor+quad+low+power ..
4/9/2022 11:02:18 PM • Razor Toys • Answered on Apr 09, 2022
Chow do I inflate a front right tire to a razor scooter
Model number that has four wheels is ................................
1/13/2022 8:01:42 AM • Razor Toys • Answered on Jan 13, 2022
CAN I ALWAYS LEAVE A PHLIPS HQ6613 RAZOR ON THE CHARGER ALL THE TIME
Hi there, charging normally takes approx. 16 hours. Do not leave the appliance connected to the mains for more than 24 hours. I have included a link for the user manual for this product.
4/18/2020 3:16:44 AM • Razor Toys • Answered on Apr 18, 2020
My Razor E300 is not working. The power button lights up but when I apply the throttle button, nothing happens. Can someone help?
so what had been hapening is that it could die depending if it was the battery that could aftfect with this. 24 volt battery, and can be ridden for up to 45 minutes after battery charging. The charge time recommended for this Razor electric scooter is about 10-12 hours after each use.
1/2/2020 10:37:25 PM • Razor Toys • Answered on Jan 02, 2020
Which frame is used for Razor 13013290 Air Scooter?
The Razor 13013290 Air Scooter's frame is made from aluminum steel which is strengthening strongly. This is why you can use the scooter for a long time.Click here for more details complete Razor 13013290 Air Scooter review
4/10/2018 5:18:24 AM • Razor Toys • Answered on Apr 10, 2018
I have a 650 razor motorcycle the battery shows fully charged but clicks when I turn throttle but it does runnsometimes
Hello Before you change the battery check thoroughly all wires and all connections!!!!
11/26/2017 6:58:46 PM • Razor Toys • Answered on Nov 26, 2017
0answers
Razor A2 Folding Kick Scooter Red Logo
6 questions posted
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
View Most Popular
Razor Toys
  • Razor Toys
Most Popular Question
razor a2
  • Toys
