20 Most Recent LeapFrog Leapster Learning Game System Questions & Answers
On my leapster gaming system blue games wont work evey time you put a game in system turns off why
maybe damaged pin connectors or corroded loose . almost works but not getting proper feed.
1/26/2015 9:36:09 AM • LeapFrog... • Answered on Jan 26, 2015
At daycare I was told my son's leapster was
Contact customer service 800-701-5327 they might be willing to replace the unit. Hope this helps!
2/14/2014 2:03:05 AM • LeapFrog... • Answered on Feb 14, 2014
2answers
Screen is totally blacked out.
leapster initially worked but now will not work, batteries are fine
1/6/2014 8:01:20 PM • LeapFrog... • Answered on Jan 06, 2014
0answers
Leapster gs reset
Be the first to answer 1/27/2013 5:01:05 AM • LeapFrog... • Posted on Jan 27, 2013Be the first to answer
My daughter has a Leapster 2 that is only about 2
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
1/10/2011 10:12:31 PM • LeapFrog... • Answered on Jan 10, 2011
0answers
0answers
When we touch the screen nothing happens - changed
This is usually cause by extremly hard impact which can dislodge the contacts between the Screen and its mating contact on the circuit board. This requires opening the device and attaching/repositioning the connector, whilst the divice is open you should place a small amount of hot glue on the outer part of the contact to prevent it moving. DO NOT use solvent based adhesives or super glue as this will severly damage the device. If this does not solve your problem contat me on [email protected] and I will try to assist you further.
6/20/2010 12:35:29 PM • LeapFrog... • Answered on Jun 20, 2010
Touch screen doesn't work
Contact Customer Service they may be able to replace the unit even after warranty 800-701-5327
10/13/2009 7:40:11 PM • LeapFrog... • Answered on Oct 13, 2009
The sylus does not work anymore
Contact Customer Service the might be willing to replace the unit even after the warranty has expired 800-701-5327
10/13/2009 7:31:37 PM • LeapFrog... • Answered on Oct 13, 2009
Touch screen not working
Contact Customer Service they might be willing to replace the unit even after warranty has expired 800-701-5327
10/13/2009 7:30:27 PM • LeapFrog... • Answered on Oct 13, 2009
Can't see screen even after new batteries
Contact Customer Service they might be willing to replace the unit even after warranty 800-701-5327
10/13/2009 7:29:19 PM • LeapFrog... • Answered on Oct 13, 2009
2answers
Put new batteries and it won't come on
There are a number of possible reasons your toy may have stopped working. Sometimes it helps to clean the battery compartment with a dry cotton swab or cloth. Rub the gold contacts inside the battery compartment to release any dust or film. You can also use an eraser to 'erase' and clean the contacts. Once you have cleaned the contacts, please make sure to install new non-rechargeable batteries before turning your unit on.
If the toy still does not work, it may have been dropped or handled improperly
10/13/2009 7:27:50 PM • LeapFrog... • Answered on Oct 13, 2009
Cant sign in
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
8/11/2009 7:54:52 PM • LeapFrog... • Answered on Aug 11, 2009
We have leapster two, we have power but the pen
8/11/2009 7:44:49 PM • LeapFrog... • Answered on Aug 11, 2009
0answers
Stuck Leapster 2
Be the first to answer 6/30/2009 6:33:40 PM • LeapFrog... • Posted on Jun 30, 2009Be the first to answer
LeapFrog Leapster Learning Game System Logo
35 questions posted
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
View Most Popular
LeapFrog Toys
  • LeapFrog Toys
Most Popular Question
daughter leapster 2 only about 2
  • Toys
