20 Most Recent Chicco Vespa Sit N' Ride Scooter Questions & Answers
My Vespa LX50 won't start.
I have had the same problem with my LX 50. You have to make sure you turn it on often to keep it in good shape. I didn't turn it on for a long time during the winter and it didn't wanna start in the spring. I bought a fluid that you put in the gas tank that cleans off the insides when the gasoline runs through. I have to double check what fluid it was. But it worked and now it turns on.
8/10/2010 10:19:20 AM • Chicco Vespa Sit... • Answered on Aug 10, 2010
0answers
Have Chicco 4 in 1
Be the first to answer 12/22/2012 11:03:38 AM • Chicco Toys • Posted on Dec 22, 2012Be the first to answer
2answers
I TOOK CHICCO CAR SEAT
Good day!!!!
Installing your Chicco KeyFit car seat correctly is essential in keeping your infant safe. You can use the Chicco KeyFit car seat for children from 4 pounds to 30 pounds. You can install the car seat in your vehicle using one of two options. Instructions
  1. Vehicle Belt
    • 1 Park your vehicle on a level surface to ensure the car seat is installed in a level position.
    • 2 Store the LATCH connectors if you use a seat belt to secure the car seat. LATCH is a child restraint attachment system that comes in a number of cars manufactured after Sept. 1, 2002. Lift up on the LATCH release lever and pull the LATCH connectors out of their storage pockets. Insert the LATCH connectors into the storage pockets, pull the LATCH strap to secure them, and then roll up the pull strap and tuck it in the storage pocket.
    • 3 Place the base of the Chicco KeyFit car seat in a forward facing vehicle seat with the recline foot against the back of the seat.
    • 4 Push the recline buttons on each side of the base while lifting the base to adjust the base angle. The base is positioned correctly when the bubble is between the arrows on the recline indicator on the side of the base.
    • 5 Insert the vehicle belt through one opening in the base, across the base and out the other opening.
    • 6 Push the base firmly down and pull on the vehicle belt to tighten the belt.
    • 7 Slide the vehicle shoulder belt into the shoulder belt lock-off on the side of the base. You should put the belt only in the shoulder lock-off on the opposite side of where the seat belt buckles.
    • 8 Check to make sure the seat belt is tight, the base is stable and the bubble on the recline indicator is between the arrows.
    • 9 Line up the carrier with the base and push the carrier firmly into the base. You should hear a click when it is secure, but pull up on the carrier to make sure it is latched.
    LATCH
    • 1 Park your vehicle on a level surface for proper installation.
    • 2 Lift the LATCH release lever and remove the LATCH connectors from their storage pockets.
    • 3 Place the base in a forward facing vehicle seat with the recline foot against the back of the seat. Follow Step 4 in Section 1 to set the angle of the base.
    • 4 Push the LATCH connectors firmly onto the LATCH anchor bar in your vehicle. You should hear a click when they are attached, but you can make sure they are secure by pulling on the straps. The Chicco KeyFit car seat is designed for use with lower LATCH anchors that are 11 inches apart. Verify the spacing in your vehicle in your owner's manual.
    • 5 Press the base of the car seat down and pull up on the LATCH pull strap to tighten the LATCH belts. Tuck the pull strap into its storage pocket and attach the carrier.
And you can view this manual to see the actual installation with picture:
http://www.juststrollers.com/images/pdf2/CIU032.pdf
Hope it helps..
Thanks for using fixya...
9/24/2011 4:42:43 PM • Chicco Toys • Answered on Sep 24, 2011
I have lost the strap
You may order replacement parts by contacting Customer Service at 1-877-424-4226. Parts like this are usually only available through the manufacturer.
5/12/2011 12:15:13 AM • Chicco Toys • Answered on May 12, 2011
Need some new straps for
LAst time I tried - no spare Chicco parts were available - when its worn out - then its worn out - its a shame but times change!
5/5/2011 11:37:39 AM • Chicco Toys • Answered on May 05, 2011
I have a chicco highchair
Try asking here
3/12/2011 12:49:07 PM • Chicco Toys • Answered on Mar 12, 2011
0answers
Where can I buy a
Be the first to answer 10/28/2010 8:59:20 AM • Chicco Toys • Posted on Oct 28, 2010Be the first to answer
0answers
Need to buy one back roller (wheel) for chicco
check out their site: chiccousa.com and contact customer service. they should be able to help with parts.
8/18/2009 3:00:16 PM • Chicco Toys • Answered on Aug 18, 2009
4answers
Chicco Mama highchair crotch strap that
The straps for Mamma are currently not available for sale on the Internet. All you find are requests from buyers that need replacement straps.
Straps for Polly and happy snack are commonly available , from third party sellers or distributed by Chicco.
The harness for the Polly high chair is a 5 points harness very similar to chicco Mamma.
To test if the happy snack harness will fit you can go to a Chicco Shop, taking along the Chicco Mamma cover, and compare the holes in the cover with the Happy snack or Polly's one, then if it does fit, you can order the replacement harness at the shop, they will be happy to help.
Polly harness:
Chicco mamma:
Chicco polly:
Happy snack:
GENUINE CHICCO POLLY HIGHCHAIR REPLACEMENT HARNESS NEW
CHICCO HAPPY SNACK HIGHCHAIR REPLACEMENT HARNESS
All I can tell you is that all over the Internet there is NOT one single Chicco Mamma harness available for sale. Only the cover or the harness for different models.
If the Polly or Happy snack harness does not fit , then the only alternative is looking periodically on Ebay, or keep calling Chicco until someone decides to send somebody to look into the old replacement parts stored somewhere in a warehouse.
I hope this can help. This research wasted a lot of time, and I decided to post the same, even if the harness is not available. Hope not to get any negative rating.
Please let me know how it goes.
Regards.
G.
7/29/2009 11:26:40 AM • Chicco Toys • Answered on Jul 29, 2009
2answers
Do you have any good craft ideas for kids under six?
I was able to find you this website with all kinds of great craft kits for pre-kindergarteners.
3/26/2024 11:30:29 AM • Toys • Answered on Mar 26, 2024
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part: 1. Contact the Manufacturer: - Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod. - Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component. 2. Check for Spare Parts: - Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components. - Look for any contact information provided for customer support or spare parts inquiries. 3. Online Search: - Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase. - Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture. 4. Local Retailers: - Visit local baby product stores or furniture stores that carry nursery items. - Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component. 5. Custom Fabrication: - If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib. - Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM • Toys • Answered on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
  1. Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
  2. Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
  3. Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
  4. Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
  5. Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM • Toys • Answered on Mar 21, 2024
3answers
I heard about a pretend toy store game to play with children. Does anyone know how it works? I am not so good at making games up.
This game is a great one to play with kids on a wet afternoon stuck indoors. Basically use their toys to turn an area of the house into a toy store. Get the kids involved in choosing the games they would like to 'sell'. Write prices lists and stick them somewhere that the kids can see and reach ie Lego sets - $4, Dolls - $2
If you don't have any pretend money, you can make your own with the kids, then divide up the tasks and let them enjoy many hours of pretend shopping.
3/8/2024 4:48:19 AM • Toys • Answered on Mar 08, 2024
Chicco Vespa Sit N' Ride Scooter Logo
3 questions posted
Top Chicco Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Chicco Toy Expert? Answer questions, earn points and help others
View Most Popular
Chicco Toys
  • Chicco Toys
Most Popular Question
chicco vespa sit n 39 ride scooter
  • Toys
