20 Most Recent Traxxas Stampede Monster Truck Rtrw/Xl 5 Questions & Answers
4answers
My RC Traxxas Stampede stopped working. The
what has happened is the brushes have lost contact with the shaft you need to clean them with some oil move the wheels back and forth with you hands after you added the oil to work it in use a very small screw driver to clean the shaft (past end) whale you are spinning the wjeels with you hands should work. I just performed that operation my self today. Same thing my xl5 steerinrg worked but no go............Good Luck,
5/13/2015 9:19:38 AM • Traxxas Stampede... • Answered on May 13, 2015
Ez set button
The set button has a tendency to get stuck, try blow pressurised air around the button that might help. Else you have to disassemble the esc to get the dirt out, but you probably won't do that to a brand new esc.
1/16/2014 11:48:05 AM • Traxxas Stampede... • Answered on Jan 16, 2014
Steering backward
Reverse steering channel on transmitter, there is a little switch for that.
7/31/2013 8:35:43 AM • Traxxas Stampede... • Answered on Jul 31, 2013
I have 2traxxas 1 withvxles3brushless upgrade the other is maxd with xl5 550motor should they run on diff channel because mine freeked out fullthrotel had pull bat conect to kill it
If you are using 2.4 GHz you shouldn't have problems with channels, otherwise you have to use crystals for 2 different channels to avoid this problem.
7/31/2013 8:31:49 AM • Traxxas Stampede... • Answered on Jul 31, 2013
My car will turn but it will not go forwards or backwards
The servo outputs are disconnected or loose. Try wiggling the plugs that go from the reciever to the servos...
3/27/2013 2:36:07 AM • Traxxas Stampede... • Answered on Mar 27, 2013
When i try to go forward it does not go ,i can hear the engine running but no movement
tighten the tension on the slip clutch , but not too tight, as that will make the engine stall
3/7/2013 4:56:59 PM • Traxxas Stampede... • Answered on Mar 07, 2013
2answers
My RC Traxxas Stampede stop working. The steering
Spin the rear wheels and make sure nothing such as a small stone is binding something up in the driveline. Check to make sure the motor has not gotten disconnected from the ESC. If you still have problems with it post again and I will try to look further into it.
1/22/2013 5:43:15 PM • Traxxas Stampede... • Answered on Jan 22, 2013
2answers
Problem with my traxxas stampede xl5 just stopped working.
It sounds like the battery is defective, that causes it to lose it charge very quickly.
3/13/2012 1:26:16 PM • Traxxas Stampede... • Answered on Mar 13, 2012
Where are brusheslocated
inside the motor
3/13/2012 1:15:12 PM • Traxxas Stampede... • Answered on Mar 13, 2012
The light, on the XL5
thats probably because you are using a nimh battery and lipo low voltage detection is off
1/26/2012 9:58:24 PM • Traxxas Stampede... • Answered on Jan 26, 2012
Traxxas Stampede Monster Truck Rtrw/Xl 5 Logo
90 questions posted
Top Traxxas Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
View Most Popular
Traxxas Toys
  • Traxxas Toys
Most Popular Question
  • Toys
