20 Most Recent Polaris 800 Twin Sportsman Ride on Toy Questions & Answers
Smart pedal stuck on peg perego polaris sportsman xp850 24 volt could not stop vehicle
sounds like the plunger switch in the foot pedal is sticking or is bad
8/16/2017 2:19:20 PM • Polaris 800 Twin... • Answered on Aug 16, 2017
Our peg perego polaris sportsman 800 twin is running without ingaging the foot pedel
sounds like the foot pedal plunger switch is bad
8/16/2017 2:14:39 PM • Polaris 800 Twin... • Answered on Aug 16, 2017
I had to replace the rectifier because it burnt out, when I turn on the ignition lights come on but when I turn the ignition to start nothing happens, starter wont turn over
Check battery volltage to make sure battery is still at opperating voltage.Sometimes dash lights will come on if battery is to low to engage starter.
11/10/2015 7:40:14 PM • Polaris 800 Twin... • Answered on Nov 10, 2015
My Polaris atv' s fuel injector will not shut off, and the engine will not turn over
Do not try to spin engine over, Engine cylinder or cylinders are more than likely full of fuel . Injector is more than likely bad or pcm has got inj. held open.
11/10/2015 7:14:01 PM • Polaris 800 Twin... • Answered on Nov 10, 2015
I got a 95 Polaris sportsman 400 4x4 i bought a new battery i did everything i had to before putting it in the quad i went riding for a couple hours and on the way home the lights would go dim when i
Most likely your Rectifier has gone bad that is like the alternator to your Polaris. In other words the rectifier is what charges the battery and keeps it charged up. You should check it next.
2/3/2015 3:46:34 AM • Polaris 800 Twin... • Answered on Feb 03, 2015
Why my polaries atv engine stop while using it for 1 hour at low speed
One of three possibilities 1. Radiator core has trash in fins. 2. Radiator coolant is low. 3 cracked rings
10/15/2014 3:25:56 PM • Polaris 800 Twin... • Answered on Oct 15, 2014
I have a polaris 800
its a known issue with these, you'll need a motor and upgrade kit, let me know if you need one
7/31/2014 1:12:24 PM • Polaris 800 Twin... • Answered on Jul 31, 2014
Peg perego polaris 700 4-wheeler wont run
Had the same problem. Once a year open (if possible) gas throttle and gear shift. Use a standard lubricating spray on everything. (power off first) shake and use compressed air to spread. Potmeters are dryed up and dont get signal. Let it dry after you sprayed it some times. Make shure you move parts. Connect and should be ok.
7/5/2014 4:20:58 AM • Polaris 800 Twin... • Answered on Jul 05, 2014
I can't get the to stop. What part does that job?
What do you mean you can't get it to stop?
12/10/2012 5:46:31 PM • Polaris 800 Twin... • Answered on Dec 10, 2012
2answers
This 800 sportsman will run for a few minuetes
The polaris 800's have a known issue with the thermal switches over heating, then they cut out after 10 minutes then after you wait about 5 minutes they come back on. Peg perego has a replacement kit with contains a new circuit board, thermals switches and two new 350 watt motors, I personally have replaced about 15 of them, its a pretty simple process
12/10/2012 5:40:54 PM • Polaris 800 Twin... • Answered on Dec 10, 2012
Polaris 800 Twin Sportsman Ride on Toy Logo
121 questions posted
Top Polaris Toys Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Polaris Toy Expert? Answer questions, earn points and help others
View Most Popular
Polaris Toys
  • Polaris Toys
Most Popular Question
got 95 polaris sportsman 400 4x4 bought
  • Toys
