20 Most Recent
Peg Perego Ride On Santa Fe Train Questions & Answers
The red button has worked before but now it only
the red button only controls the sounds which run off of 3 aaa batteries, the black button controls the motor which runs off of the 6v sla battery, make sure that under the seat the battery is connected to the train
Peg Perego Thomas The Train - Ride On wont go but horn &whistle works
If the Peg Perego Thomas The Train ride-on is not moving but the horn and whistle are still working, it's likely an issue with the motor or the gearbox. Here are a few troubleshooting steps you can try:
- Check the battery: Make sure the battery is fully charged and properly connected. If the battery is old, it may need to be replaced.
- Check the wiring: Inspect the wiring for any damage or loose connections. Ensure that the wiring is properly connected to the motor and gearbox.
- Check the motor: The motor may be burnt out or malfunctioning. Use a multimeter to test the motor and see if it's receiving power.
- Check the gearbox: The gearbox may be jammed or worn out. Inspect the gearbox for any damage or obstructions. Try lubricating the gears with some WD-40 to see if that helps.
If none of these steps resolve the issue, it may be best to contact Peg Perego customer service or take the ride-on to a certified repair shop.
