20 Most Recent
5900 SST 2-Way Security System / Remote Start System with Responder S Questions & Answers
How to program a remote control viper 5900 for a
Should be a switch for overriding the alarm under the drivers side dash. Two wires going to it (grey black) with a push button on the end if it. Have the driver door open and turn the ignition to on not running,,,, push the valet button and let go and then push and hold valet button........ Hit lock on the transmitter one time while still holding the valet button down. You should get a chirp for entering program and then when you lock on the remote it will make another chirp. But the chirp will sound awkward. Let go of valet and and turn truck off. And test remote. If that's doesn't work you may need to follow all the same steps but instead if press once and press and hold you will need to push 8 times and hold on the 9th and hit lock on the remote. I'm pretty sure the it's sequence is for alarm security and 8 steps is for remote start only models. Food for though if my mind is working backwards. Best off luck. All else fails I'm sure a shop will do for about 20$
The battery was taken out
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
My viper 5900 has no
If you are not getting any sound then the system may be in valet. To find out if it is in valet your status l.e.d. light should be solid and not flashing. if the light is not even on then maybe your horn was never hooked up, but if the light is on then you must take it out of valet.To take it out of velet you have to turn on the ignition of the car and then shut it off... With-in 5 seconds you have to press the valet overide button. The status light should go off when you do this. The other way of taking it - in and out of valet is to open a door and press the.... lock..unlock..lock unlock... lock butons in that order.
Mts mode for preset manual trans auto start
There is a sequence necessary to set the Viper every time you exit the vehicle: park the vehicle, put in neutral, place foot on brake, set parking brake,remove foot from brake, remote start vehicle with remote, remove key (vehicle should remain running), exit vehicle and close door, arm the alarm with remote (vehicle should shut down). The system is now set for MTS remote start. Test the system by remote starting the vehicle now (it should remote start at this point). If you open any door after the MTS remote start has been set, you will have to do the programming sequence again.This is a safety feature because something may have changed, i.e. parking brake released when the door was opened. You have to do this sequence each time you park the vehicle if you intend to use the remote start feature.
If this does not work, there may be an issue with the installation, i.e., the door trigger connection. Using dome supervision as a door trigger won't work because during the arming portion of the above mention programming sequence(when the vehicle shuts down), the interior lights will illuminate and the Viper will read it as a door opening. So, actual door trigger wires must be used.
My remote starter for my viper 5900 2 way trans
Try reprogramming the remote. Open the door, turn ignition on, press and release valet switch one time, then press and hold valet switch while pressing lock button on remote.You should hear a confirmation chirp from the alarm. Release both buttons.Turn off ignition. test.
Viper 5900 this morning i noticed i couldn't
The 3 squiggly lines are meant to show that the car is running in remote start mode. As far as the door locks not working, that could be caused by a few things.. This unit does have a history of the antenna going bad, and will work sometimes, and not others. I suggest you take it to the place that installed it, and have them check it out..
My viper 5900 has no reaction to someone touching
You have to find the clear mini shock sensor and use a philips screw driver to tune it up. As far as the horn that is a not a simple on/off feature, your installer would have needed to charge extra to do that.
