20 Most Recent
AutoCommand Remote Start and Security with Keyless Entry Questions & Answers
I need to know if model #20024 starter unit will
This unit will work with your vehicle but if your vehicle is equipped with a transponder type security system you will need to add an immobilizer bypass.
Some bypasses that are available can be found at the following links:
http://www.xpresskit.com/VehicleCompatibility.aspx?p=-1&year=2007&make=Chevrolet&model=Aveo&ps=1&s=0
http://www.idatalink.com/search/index/model/4770
My remote start starts my santa fe 2004 on its own
Check out this site. It is the manual for the alarm that is pictured. Scroll to the second to last page and it will tell you how to disable "daily starting". I think you have to hold, both, the light and aux buttons for three seconds to activate or deactivate daily starting.
Remote start is intermittent working
the problem is your car is equiped with a passlock system you need a by pass mod. part number 555-L this is a dei part number this is the only company i use. it is a simple three wire hook up. if you got this far you will not have any trouble. one other thing to check is your ignition wirers make sure they have power when they are suposed to.if your still having problems or need more info on getting part let me know. i have alot of exp. with auto starts and keyless entry.
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
