20 Most Recent Bulldog& Remote Alarm System With 1-wire Hookup Questions & Answers
Bulldog remote starter RS82 will not start car
Does it try and do anything ?
11/7/2013 9:54:44 PM • Bulldog& Remote... • Answered on Nov 07, 2013
How to hook up bulldog
Hello my name is Israel and I will be glad to help you out. This alarm system uses a drop in voltage sensor to work. First mount the siren on a firm ground metal of the vehicle. Be sure that the base is mounted on metal and not plastic. Then, the best way for the system to work is to run the wire into the vehicle cab and connet the one wire to the positive side of either the dome light fuse or dome light wire. This will help in it "catching" voltage drops when the lights go on. Good Luck.
2/15/2011 9:27:51 PM • Bulldog& Remote... • Answered on Feb 15, 2011
I have a RS114 installed in a Ford F-150.Was
check the fuse on the main red wire on the remote start unit, I have had a couple that are defective, that clip that holds the fuse tight is not tight
3/6/2010 3:09:00 AM • Bulldog& Remote... • Answered on Mar 06, 2010
Hooking up new tv to
are you using a bulldog product for this ?
1/25/2010 2:46:57 AM • Bulldog& Remote... • Answered on Jan 25, 2010
I have installed a bulldog security rs82p on a
put your key in the ignition leave it in the off position, now press the remote starter, if it starts you need to adjust the key in the 791, or adjust the transponder loop around the key chamber
1/25/2010 2:03:05 AM • Bulldog& Remote... • Answered on Jan 25, 2010
Installed a bulldoge security system into a 2008
you could take the fuse out of the main alarm harness for a couple of days and see if your problem persists
1/25/2010 1:58:59 AM • Bulldog& Remote... • Answered on Jan 25, 2010
Set up
Turn the valet switch on, start the car with your key wait 15 sec, press the * star button 2 times with the car running, it should beep and program if not turn valet switch the other way and try again, if still nothing post me back and we will go from there
9/29/2009 3:29:24 AM • Bulldog& Remote... • Answered on Sep 29, 2009
Where may I obtain a replacement remote and directions for Bull
go to www.BulldogSecurity.com and do a little looking. I had the Same Problem with Mine and got mine through their Website. They will tell you also how to Program the New Remote to match your Starter. Let me Know how it Goes!
1/2/2009 3:52:31 PM • Bulldog& Remote... • Answered on Jan 02, 2009
I have a bulldog remote start. It worked great
I would say get the schematics from bulldog and trace the lines, it sounds like either the wiring is bad or one of the relays is bad.
10/24/2013 7:19:48 PM • Bulldog Security... • Answered on Oct 24, 2013
I installed the KE 1702
where did you tie into the domelight supervision? did you use the yellow black wire in the kick panel? does your unit have dip switches in it? it may be seeing ground when it is not supposed to. not sure but let me know how you hooked it up and what wire you used and i will let you know.
10/20/2009 9:55:02 PM • Bulldog Security... • Answered on Oct 20, 2009
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
3/28/2024 3:46:39 AM • Vehicle Parts &... • Answered on Mar 28, 2024
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
3/24/2024 2:38:44 PM • Vehicle Parts &... • Answered on Mar 24, 2024
3answers
What is hashtag
hash·tag noun
  1. (on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
    • the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
2/25/2024 9:46:45 AM • Vehicle Parts &... • Answered on Feb 25, 2024
Manual for XT-90LCD-autopage auto start
Yes
12/20/2023 6:51:49 PM • Vehicle Parts &... • Answered on Dec 20, 2023
Dynamite autopower DP-300 will not fully recharge no matter how long I leave it on the charger does not go above low charge
Hi, You need to check the output on the charger first, with a meter. Let me know and we will go from there.
10/22/2023 10:19:36 PM • Vehicle Parts &... • Answered on Oct 22, 2023
Bulldog& Remote Alarm System With 1-wire Hookup Logo
Popular Tags
11 questions posted
Top Bulldog Security Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
John
John
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Bulldog Security Vehicle Parts & Accessories
Most Popular Question
rs114 installed in ford f 150
  • Vehicle Parts & Accessories
