20 Most Recent
Life Fitness 9500 HR Recumbent Bike Next Generation Questions & Answers
Lifefitness recumbent bike battery not charging
Possible causes for a dead battery or it not holding charge
1.
Battery has lost its ability to hold a charge (dead battery)
2. Charging system on unit has failed (battery cables, alternator, or alternator control board)
3. Stuck key on the
display is causing a constant draw from the battery.
For any further troubleshooting you can contact our Technical Support Team and we would be happy to help you,
online or by phone 888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
Life Fitness Club Series+ treadmill, miles to kilometers?
Hi Yuri,
Hope so you're doing well, the distance unit from miles to kilometers on the Life Fitness Club Series+ treadmill, there are a few steps you can try before contacting Life Fitness support:
- Warm reset: Press the CLEAR key twice, and then hold down the ENTER key. The treadmill should perform a "warm" reset and beep three times, indicating that the USER MENU has been activated. After the reset, check if you can access the distance unit setting.
- Manual access: Alternatively, you can try holding down the ENTER key while turning on the treadmill. The message "USER MENU" should appear, and after a second, the MESSAGE CENTER will display the first menu item. Navigate through the menu options using the appropriate keys until you find the distance unit setting.
Hope so this will work for you!
Regards,
Bryce June
Lifefitness se3 hang up how can i fix it ?
Sure, here are some steps you can try to fix the issue with your Lifefitness SE3 console:
- Perform a system diagnosis: The Lifefitness SE3 console has a built-in diagnostic tool that can help you identify any hardware or software issues. To access this tool, press and hold the 'Home' and 'Volume Up' buttons for 5 seconds. Then select 'System Diagnostics' from the menu and follow the prompts to perform the diagnosis.
- Check the system logs: The Lifefitness SE3 console logs all system events, which can help you identify the cause of the hang-up. To access the logs, go to the settings menu and select 'System Logs'. Look for any errors or warnings that may indicate a problem.
- Update the BIOS: The Lifefitness SE3 console has a BIOS (basic input/output system) that controls the hardware and software interactions. Updating the BIOS can sometimes fix issues with the console. To update the BIOS, download the latest BIOS firmware from the Lifefitness website and follow the instructions provided.
- Check the storage device: The Lifefitness SE3 console uses an embedded storage device to store data and software. If this storage device is faulty, it can cause the console to hang-up. To check the storage device, go to the settings menu and select 'Storage'. Look for any errors or warnings that may indicate a problem.
- Reinstall the operating system: If none of the above steps work, you may need to reinstall the operating system on the console. To do this, download the latest operating system firmware from the Lifefitness website and follow the instructions provided.
How can I turn down beeping on Life Fitness 95xi elliptical? My wife pedals slowly on it and it's constantly restarting and beeping and beeping and beeping.
To turn down or turn off the beeping on your Life Fitness 95xi elliptical, follow these steps:
- Locate the control panel: The control panel is usually located near the handlebars or on the console of the elliptical.
- Find the sound or beep settings: Look for a sound or beep option in the settings menu.
- Adjust the volume or turn off the beeping: Use the up and down buttons to adjust the volume of the beep, or turn off the beep completely.
- Save the changes: Once you have made the necessary adjustments, be sure to save the changes by pressing the "Save" or "Enter" button.
If you are unable to find the sound or beep settings, consult the owner's manual or contact the manufacturer for assistance. Keep in mind that some beeps are important safety warnings, and disabling them could be dangerous.
Life FItness elliptical model X7 has too much resistance on startup. Prevents use for warming up.
It sounds like the resistance on your Life Fitness X7 elliptical is set too high for the machine to be used effectively as a warm-up tool. There are a few things you can try to adjust the resistance on the machine.
- Check the user manual that came with the elliptical to see if there are any specific instructions for adjusting the resistance.
- Check the resistance settings on the dashboard to ensure that they are set to the correct level.
- Check the resistance adjustment knob or lever to ensure that it is not stuck or jammed in place.
- Check the belt tension on the elliptical to ensure that it is not too tight.
- Check to ensure that there is no debris or dust in the resistance mechanism.
- If the issue still persists after trying the above steps, it may be best to contact Life Fitness technical support or consult a technician for further assistance.
It is also a good idea to inspect the machine overall for any damage or wear.
If all else fails, the used elliptical may have a defect or may not be compatible with your needs. You may need to consider purchasing a new one or a different model for your clients warm-up needs.
