20 Most Recent 2003 kawasaki KX 125 Questions & Answers
3answers
How can i find out what year motor is on my kx80
check your VIN number! The eighth number will tell you what year your bike was produced.
4/26/2021 2:10:33 AM • 2003 kawasaki KX... • Answered on Apr 26, 2021
Whats up with my bike?
jet size and exhaust muffler are not connected failing at high rpms indicates a problem coil or capacitor or failing ignition control module if it has points or cdi ignition it could be from worn shaft that is wobbling at speed causing the miss
6/24/2017 4:15:10 AM • 2003 kawasaki KX... • Answered on Jun 24, 2017
Where is the vin number for a 2002 kx 100 kawasaki
Check VIN location at this page: http://vin-location.com/
9/9/2016 8:30:14 PM • 2003 kawasaki KX... • Answered on Sep 09, 2016
2answers
Bike keeps fowling plugs could it be the
usually 2 strokes foul plugs when the oil is two strong in my old bike i mixed the gas 40:1 try that and if it dosent work i would take it to your nearest dealer and get them to check it out
4/28/2015 2:01:29 PM • 2003 kawasaki KX... • Answered on Apr 28, 2015
Bike got spark and compression but doesnt start try to push but no luck
Check the timing it should be set at top dead center or a hair before top dead center, the other issue could be it's not pulling fuel which would mean it needs a good carb cleaning
7/11/2014 7:41:20 PM • 2003 kawasaki KX... • Answered on Jul 11, 2014
Why wont my 2003 kx125 hit the power band, right as it would hit it it just back fires
Could be the power valve is dirty or blocked from operating. May be a carburetor problem too. Has the carb been cleaned lately?
4/13/2014 7:45:54 PM • 2003 kawasaki KX... • Answered on Apr 13, 2014
2answers
Kx 125 1992 wont start
sounds like the rings are fried and needs a new piston and rings.. for an 80 there about 110 bucks for the whole kit
3/31/2014 2:04:14 PM • 2003 kawasaki KX... • Answered on Mar 31, 2014
I dont know the year of my motor i have no vin number
Hi, I am confused, your problem question banner shows the year as 2003 for your Kwaka. Vin number is normally for the frame/chassis. If you look around the engine you should see a stamped/etched alpha numeric code. If you call Kawasaki they should be able to tell you the details regarding this code.
1/30/2014 3:01:53 PM • 2003 kawasaki KX... • Answered on Jan 30, 2014
Idol to high
You have to adjust your idle screw on the side of the motor ...it should be by your carb. Turn your bike on and then turn that screw to the left until your motor calms down and has the correct idle speed.
10/28/2013 10:17:38 PM • 2003 kawasaki KX... • Answered on Oct 28, 2013
2answers
Kx80 has no power
Service your carb.I think you will find your pilot jet is blocked.
10/15/2013 11:35:53 AM • 2003 kawasaki KX... • Answered on Oct 15, 2013
Wont upshift
If your bike has shift indexers they could be out of adjustment.
10/14/2013 11:11:08 PM • 2003 kawasaki KX... • Answered on Oct 14, 2013
How much oil is in my V65 sabre mono shock?
i got kx80 and dont no the year cud u help me frame kx080L-004594 engine kx080EE049741
8/26/2013 1:12:01 PM • 2003 kawasaki KX... • Answered on Aug 26, 2013
Kx 125 sputtering in high rpms
check and make sure choke is opening all the way,if it is only opening part way could explain why you don't need to use choke at all to start and then at higher rpm's it is not getting enough air causing it to basically choke it self out.
8/9/2013 4:27:53 AM • 2003 kawasaki KX... • Answered on Aug 09, 2013
Clutch problems
Release arm in engine is broke.
6/8/2013 4:07:13 PM • 2003 kawasaki KX... • Answered on Jun 08, 2013
2answers
Got compression, got spark, getting gas wont start
clean carb and check jets
4/22/2013 8:36:34 PM • 2003 kawasaki KX... • Answered on Apr 22, 2013
2003 kawasaki KX 125 Logo
326 questions posted
Popular Products
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
View Most Popular
KX 125 kawasaki
  • KX 125 kawasaki
Most Popular Question
bike wont start after not being used
  • Motorcycles
