20 Most Recent
Opera Software Mini Questions & Answers
How do I remove opera from my PC
Click on Start, and the Control Panel.
Then, depending on which version of windows you are running, choose Add/Remove Programs, Programs and Features, or Uninstall a program.
Choose Opera from the list, and click on uninstall or Change. Follow the prompts.
How i can use internet
- To use internet service in your mobile at least you need a gprs facility mobile
- If you have a gprs able mobile you have to call your connection provider to get activated the gprs.
- Follow the step by step procedure by the service executive
- after that they will ask you to re start the mobile
- now you will be able to access the internet through your mobile phone (of course you need balance in your mobile)
Hope this helps,
Please rate if the solution was helpful, thanks!
My computer wont download operaminis
Opera Mini is a phone web browser and is only downloaded via phone.
If you want to download it, you will have to use a phone to download it.
Download it using the phone browser of the phone you want to use it on.
Simply type: http://www.mini.opera.com
and it will automatically give you the latest version for your phone.
If you want to use it on PC, use Opera's full web browser which you can download from : http://www.opera.com/
Thank you for using Fixya,
Kenneth
Fail to connect internet,my hp
CHeck for your connection setting in your Browser . Make sure that the correec tnetwork is selected and the phone is using correct configuration to connect to internet .
Filed to connect to the internet
Make sure you get the internet connection setting to the phone by calling the cellphone carrier customer care service or any other method available. Save the settings and go to Menu>Settings>configuration and for Default Configuration Setting choose one from the saved GPRS settings from you previously saved. It should work now. This path is only for a NOKIA s40 phone. since you have not mentioned your phone model the process might be little bit different. But after you save the setting from the provider the rest is easy and sometimes it works without selecting the Default Configuration Setting.
