20 Most Recent 2005 Kymco People S 200 Questions & Answers
2answers
My Kymco People S 200 scooter jerks/ misses at
carb,air filter?if it is only downhill maybe the chain can't keep up since you are at max.auto clutch?that's something different.good luck.
5/11/2018 1:44:27 PM • 2005 Kymco... • Answered on May 11, 2018
3.In percentage terms, what is the approximate increase in participation from 2005 to 2008? The increase of people is 13,000. This number has to do with the percentage
That depends on the number of participants in 2005. If you don't give the full problem then we can't give you an answer.
9/11/2014 3:04:18 AM • 2005 Kymco... • Answered on Sep 11, 2014
Hi guys,i have a kymco s200 bug it turns over but
Under the seat you should find a fuse box with the ignition fuse blown............Hope this helps.
7/28/2014 4:02:24 PM • 2005 Kymco... • Answered on Jul 28, 2014
How to access the handle bar locking mechanism on
THE REASON FOR A HANDLE BAR LOCKING MECHANISM IS TO PREVENT SOME ONE STEELING THE MOTOR CYCLE ALL I CAN SUGGEST IS GET IT DONE AT A MOTOR CYCLE SHOP.
10/19/2013 11:31:13 AM • 2005 Kymco... • Answered on Oct 19, 2013
I cannot find drain oil
u need to read your owners manual, it help me, it can help u to,take the time.
8/29/2012 10:11:21 PM • 2005 Kymco... • Answered on Aug 29, 2012
2answers
I HAVE A 2009 PEOPLE S 200 THAT JUST CLICKS WHEN I
battery is low and needs charging most likely.
5/12/2012 10:16:27 PM • 2005 Kymco... • Answered on May 12, 2012
I bought a 2005 kymco
YES, THIS MODLE HAS A OIL INJECTION AND ANY TWO STROKE OIL WILL WORK BUT TRY AND STAY WITH A MOTOR CYCLE TWO STROKE OIL THERE IS A DIFFERANCE
5/20/2011 3:06:45 PM • 2005 Kymco... • Answered on May 20, 2011
I am not sure how to start the scooter. The key
turn key to on pos then kick it over if no kick start pull left brake or clutch lever in and find start button
5/10/2011 10:01:10 AM • 2005 Kymco... • Answered on May 10, 2011
3answers
KYMCO Sputters and Dies at random
Filling the tank full is okay. The problem sounds like condensation in the gas tank has made it to the carburetor. There should be a screw or drain plug on the side or bottom of the carb float bowl. Drain the carb and also drain some gas from the fuel line to remove any water and trash in the system. Chances are this will get you back on the road.
5/6/2011 9:26:23 PM • 2005 Kymco... • Answered on May 06, 2011
The engine will not start
pull out the plug and hold it on bare metal too see if youur getting spark.
4/17/2011 7:21:50 PM • 2005 Kymco... • Answered on Apr 17, 2011
How do you remove the rear wheel on a Kymco People
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
1/19/2011 2:04:36 AM • 2005 Kymco... • Answered on Jan 19, 2011
2answers
Does the Kymco People S 200 have an alternator?
To keep things clear for you i've listed 2 things for you to check.
1.
Your bike produces its own power. It consists of a stationary stator with a (pick-up/pulse) signal generator
The rotor/flywheel is mounted onto the keyed crankshaft, and secured with a nut.
This will be on the right side of the motor, you'll have to remove a cover to get to it.
I would have this tested with an ohm meter before you remove anything.
Pulse generator coil resistance should read 70-130 Ohms.
2.
Your battery produces power to start your enegine and run some lights. After some time your battery would go dead if not recharged. Your bike has a Voltage Regulator & Rectifier built into one unit, which some people call just a voltage regulator, and some people call it an alternator.
Your above mentioned stator produces an electrical current called AC power, which probably only runs the headlights, and the rest of that AC power is converted to DC power via the Alternator/Voltage Regulator, which runs the rest of the lights and horn, etc.
Your alternator should put out 13.5 - 15.5 Volts @ 5000 rpm.
Any other reading means your Alternator is bad. Too low undercharging Too high overcharging.
Test your alternator at the battery when the motor is running.
If you need to replace your alternator, it is located under the (nose)front plastics.
Usually a 4 prong plug and one bolt securing it to the frame.
1/3/2011 4:14:59 AM • 2005 Kymco... • Answered on Jan 03, 2011
HI, I was asked by
Yes you can charge the battery with a battery tender, or battery charger, when the bike is sitting.
Your People S 200 requires a 12 v, 6Ah battery.
Fully charged will have 13.1 Volts
Undercharged 12.3 Volts
Most battery tenders use low amps to charge and wont overcharge your battery.It just maintains it at 12.5 Volts.
If you use a battery charger, be sure you monitor it regulary, as some models don't shut off.
12/13/2010 1:37:03 PM • 2005 Kymco... • Answered on Dec 13, 2010
Hi my kymco 50 can,t run with midle throtle when
Is it new or when was the last service?
12/10/2010 7:25:47 AM • 2005 Kymco... • Answered on Dec 10, 2010
After re-building my 150 (08) scootcoupe engine
Hi! I strongly suggest that you put in a genuine kymco crank assembly. Since you made some modifications, a kymco crank may resolve this. Since it's a trial and error thing for a modified scooter, the genuine crank will be close enough on resolving this. Hope this helps and thank you for using FixYa!
9/1/2010 2:10:44 PM • 2005 Kymco... • Answered on Sep 01, 2010
When I try to start
dump it the engine has siezed up
8/21/2010 2:56:07 PM • 2005 Kymco... • Answered on Aug 21, 2010
How do i put gas in my people s200
Raise seat remove gas cap and fill
8/11/2010 12:54:03 AM • 2005 Kymco... • Answered on Aug 11, 2010
2005 Kymco People S 200 Logo
Popular Tags
47 questions posted
Top Kymco Experts
Arnie Burke
Arnie Burke
littlewheel
Are you a Kymco Expert? Answer questions, earn points and help others
View Most Popular
People S 200 Kymco
  • People S 200 Kymco
Most Popular Question
bought 2005 kymco
  • Motorcycles
