20 Most Recent
2008 Keeway F-act 100 Questions & Answers
I took my carb off
if its the line at the very bottom of the carb its the overflow for the bowl and it doesnt go anywhere
Keeway fact 50 2008 just turns over but not starting
What exactly is it doing when you try to start it? A slow, lazy start is commonly a low charged or weak battery. Just spinning and not trying to start is often a 'No Spark' issue. Turning, trying to start but stalling out is usually a fuel supply problem.
11/8/2023 7:27:00 AM •
Keeway...
Answered
on Nov 08, 2023
Im looking for a diagram to where the fuel lines go on a 2014 tx125 Keeway motorcycle
I don't have specific information on a 2014 Keeway TX125 motorcycle. However, I can provide you with some general information about fuel lines in motorcycles.
The fuel lines in a motorcycle connect the fuel tank to the carburetor or fuel injector. They carry fuel from the tank to the engine, allowing the combustion process to take place. The fuel lines are typically made of rubber or plastic, and they can become brittle and cracked over time, leading to leaks.
In most motorcycles, there are two fuel lines: one for fuel delivery and another for fuel return. The fuel delivery line carries fuel from the tank to the carburetor or fuel injector, while the fuel return line carries excess fuel back to the tank. The fuel return line helps to regulate fuel pressure and prevent vapor lock.
It's important to make sure that the fuel lines in your motorcycle are properly connected and in good condition. A fuel leak can be dangerous and cause damage to your motorcycle. If you're not sure how to properly connect the fuel lines on your Keeway TX125, I would recommend consulting the motorcycle's owner's manual or taking it to a certified mechanic for assistance.
2/20/2023 7:16:45 AM •
Keeway...
Answered
on Feb 20, 2023
