20 Most Recent Ranger Communications TR-396FC 40-Channels Base CB Radio Questions & Answers
RF output power is 4 watts
Ranger... | Answered on Feb 23, 2015
Is the speaker the internal or external one ? disconnect the external speaker then take a multimeter on ohms with sound and touch the pos and neg contacts . you will hear a beep ,now look at the meter and read what ohm reading you have.check to make sure you are on band mode and not pa . If you hear nothing add an external speaker which will over ride the internal speaker and see if you still get nothing. Now that you have confirmed this you may want to take it to a tech and have them fix it. And I did a google search and found a service manual for this radio .
you cut the wires trim off some plastic and attach a spst switch on both wires.
Note - You must have an Armature License to legally perform this conversion.
1. Remove bottom cover from radio. 2. On the main PCB, locate J33. (See diagram above) 3. Locate wires on pins marked "P5" (yellow) & "P6" (grey). 4. Cut wire on "P5" (yellow) and install a SPST switch in line. 5. Cut wire on "P6" (grey) and install a SPST switch in line. NOTE: By using two of the function switches available on the radio will eliminate the need for two new switches to be installed and mounted.
Ranger... | Answered on Mar 09, 2011
check out the schematic first .It may be the same wiring .
Ranger Radio... | Answered on Oct 03, 2018
Your radio needs an alignment to bring it back to specs . Check all the frequencies according to the manual and have a tech tune it for you .
If you want to talk on AM put it on AM if you want to talk on SSB then put it on SSB. Did you recently purchase this radio? You do realize you need a ham radio license to use this ?If you are on the upper ham bands you better have a license or they will come and get you .Look at the the dial that has 1 - 7 on it. Now take the owners manual and look at the diagram of the knob . It should say something about frequencies and the frequency you need to operate on is from 26.965 to 27.405 MHZ .
Ranger Radio... | Answered on May 06, 2016
on the back of the cpu behind the frequency counter display. you will see the pins sticking out
Ranger Radio... | Answered on Jan 10, 2016
The + side of the cell is smooth on the top (no seam), and the - side has a seam going all the way around it as shown below:
This side ^ is (+) and this side ^ is (-)
Ranger Radio... | Answered on Oct 20, 2015
ship to shore communication and weather reports.
Ranger Radio... | Answered on Oct 01, 2015
Do like I just did,Google it and your answer will be an affirmitive YES.
take it to a tech , if you have to ask then you are not able to work on it . It is definatly an internal problem.
Ranger Radio... | Answered on Jul 17, 2015
I gotta get me a ranger radio with the windshield washer pump.
Ranger Communications TR-396FC 40-Channels Base CB Radio Logo
4 questions posted
Top Ranger Radio Communications Experts
Steve Allison
Steve Allison
Mike Charette
normis101
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Ranger Radio Communications
Most Popular Question
when converting texas ranger 396fc cb 10
  • Radio Communications
