20 Most Recent
NorStar M7100 Corded Phone Questions & Answers
I can't dial and outside line
Speak with your office manager or who ever is in charge of the phones, they deal with a tech or vendor that programs your phone system (not the phone itself directly). Chance are they restricted your phone.
How can I reset the
Try this:
Press "Feature (star) (star) T I M E"
and follow the display prompts.
Good Luck!
Answering machine
An answering machine would have to be setup separate from the Norstar System. Install a jack for your Line 1 and connect the answering machine.
Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Display not showing and won't adjust
That looks like that sets freaking out. I'd unplug that one for 10 seconds and see if that corrects the problem. Also, did you try another set in its place to see if the display on the sets having the issue and not the port?
Describe your NorStar M7100 Corded My phone
Your phone may have another mailbox associated with it, like the general delivery mailbox which can be mail box 100, try logging into 100 with default password of 0000. I am assuming you have 3 digit extension, if 2 digit login into mailbox 10.
Dan
