20 Most Recent
Inverter 50a Amp Plasma Cutter, Air , Cut50d 110/220vac Questions & Answers
KEB F5 Inverter error E. OH Error overheat power module this alarm always sowing how to solve this problem. Please help me
Error E. OH (overheat power module) on a KEB F5 Inverter indicates that the power module is overheating. This can be caused by a variety of factors, including a malfunctioning cooling system, a faulty power module, or a problem with the wiring or connections.
To troubleshoot the issue, you can try the following steps:
- Check the cooling system for any visible signs of damage or malfunction, such as a clogged air filter or damaged fan.
- Check the power module for any visible signs of damage or malfunction, such as burnt or damaged components.
- Check the wiring and connections to ensure that they are secure and properly connected.
- Check the F5 Inverter's fuse and circuit breaker to ensure that they are functioning properly.
If these steps do not resolve the issue, it's best to contact a professional repair service or the manufacturer for further assistance. They will be able to diagnose the problem and recommend the appropriate repairs. It's also a good idea to stop using the F5 Inverter until the issue has been resolved, as continuing to use it may cause further damage.
2/4/2023 10:03:27 AM •
Inverter...
Answered
on Feb 04, 2023
KIPOR 3000TI INVERTER. Kipor 66284 DC Receptacle. Can I run it without one safely?it's been removed
It's generally not recommended to run a KIPOR 3000TI Inverter without the Kipor 66284 DC receptacle. The DC receptacle is an important safety feature that helps to protect the inverter and any connected equipment from damage. If it has been removed, it's possible that the inverter may not function properly or may be at risk of damage.
If the DC receptacle has been removed and you are experiencing issues with the inverter, it's best to contact a professional repair service or the manufacturer for further assistance. They will be able to diagnose the problem and recommend the appropriate repairs. It's also a good idea to stop using the inverter until the issue has been resolved, as continuing to use it without the DC receptacle may cause further damage or pose a safety risk.
1/7/2023 10:49:53 PM •
Inverter...
Answered
on Jan 07, 2023
Power Star W7 Dead display and no output, any idea?
If your Power Star W7 has a dead display and no output, it's possible that there is an issue with the power supply or the display itself. Here are a few steps you can try to troubleshoot the issue:
- Check the power cord and outlet to ensure that the W7 is properly plugged in and receiving power.
- Check the power supply for any visible signs of damage or malfunction.
- Check the display for any visible signs of damage or malfunction, such as cracks or loose connections.
- Try resetting the W7 by unplugging it and waiting a few minutes before plugging it back in.
- Check the owner's manual for any troubleshooting tips or information on common issues.
If these steps do not resolve the issue, it's best to contact a professional repair service or the manufacturer for further assistance. They will be able to diagnose the problem and recommend the appropriate repairs. It's also a good idea to stop using the W7 until the issue has been resolved, as continuing to use it may cause further damage.
1/7/2023 10:48:18 PM •
Inverter...
Answered
on Jan 07, 2023
Hypertough 750-watt inverter, display-voltmeter problem
Most likely the battery volts are displaying correctly. There is a voltage drop on the battery due to its internal resistance, when you connect a supply the voltage drop is less.
If you were to put a new battery on it it might reduce the voltage drop, as long as the battery is designed for the current load it's taking.
If it's working I wouldn't worry, but if the voltage continues to drop with use I'd be thinking it needs a new battery. (Assuming the battery is charging correctly)
12/9/2022 11:57:04 PM •
Inverter...
Answered
on Dec 09, 2022
