20 Most Recent Eliminator MotoMaster Mobile Power Inverter 175 W Questions & Answers
Ocp code
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiC9dTmy6ODAxUpmokEHW69CjgQFnoECA4QAw&url=https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FOpen%25E2%2580%2593closed_principle%23%3A~%3Atext%3DIn%2520object%252Doriented%2520programming%252C%2520the%2Cwithout%2520modifying%2520its%2520source%2520code.&usg=AOvVaw1Jpi8fgKYUL30yZ5JXAjry&cshid=1703266989913712&opi=89978449
12/22/2023 5:43:31 PM • Eliminator... • Answered on Dec 22, 2023
I need to replace the cigarette lighter plug on my
  • One wire is the hot and the other wire is the ground.
To find which wire is the ground wire,Take a volt meter and set it on ohms,connect one of volt meters leads to case ground,take the other volt meters lead and touch it to one on the inverters wire,when the needle or digital read out advances or makes a buzzing sound, depending on the type of meter you use,that is the ground side. Black is usually ground and red hot.center connector for lighter socket is the hot side.
11/20/2009 4:41:34 AM • Eliminator... • Answered on Nov 20, 2009
2answers
3000 watt eliminator with OLP and LUP CODES any Ideas
Assuming you have a 12VDC In 120V AC out 3000W inverter. LUP indicates battery voltage is low, so firstly make sure: 1. You 12V battery is good, it's large enough a minimum of 75AH and probably much larger is recommended and it's fully charged. 2. Verify you are using the correct size copper wires from battery to the Inverter DC INPUT(s). If you keep wire short the wire size can be smaller, but if the DC input wires are longer then you will need to use thicker copper wires. At MAx load you would be taking 250 AMP from battery, so for a 5% Volatge drop of .6 V for a 10 ft length of cables from battery to Inverter you would need to use a 1AWG copper cable. http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=0.4066&voltage=12&phase=dc&noofconductor=1&distance=10&distanceunit=feet&eres=125&x=37&y=8 OLP is a overload condition, which means you may have to many high powered AC powered things connected to the Inverters AC outlets or maybe something that has large start up surge, ie devices large electric motors. Or it could be all due to a faulty Inverter.
9/27/2020 2:26:17 PM • Eliminator... • Answered on Sep 27, 2020
How do I charge my motomaster eliminator 1400
I have seen video's on google about how to charge the motom master eliminator 1400.
9/7/2020 6:22:41 AM • Eliminator... • Answered on Sep 07, 2020
My compressor won't turn off on my Motomaster Eliminator 1400/700. It's 2.5 months old, how do you turn it off?
Unfortunately, from reviews I have seen on this product, it is likely it is not going to turn off. In other words, the Motomaster is junk. If I were you, I would return this and select another product. The Dewalt DXAEPS2 may be worth looking into. It has a 2800 Peak/1400 amp Jumpstarter, a 1000 watt inverter and a 120 PSI compressor. Sorry about the problems you'r having with your current Start pack.
9/14/2019 12:50:21 PM • Eliminator... • Answered on Sep 14, 2019
Can MotoMaster Eliminator 1400A Booster Pack be charged from 220V outlet?
no it can not
11/21/2018 9:41:34 PM • Eliminator... • Answered on Nov 21, 2018
0answers
Red fault lite on and no power to ac and alarm continuouse why
The inverter may be in low voltage shutdown. If battery is marginal, wires small, or load significant, this all has effect on the voltage the inverter is seeing.
1/19/2012 8:14:23 AM • Eliminator... • Answered on Jan 19, 2012
On the Elimanator 3000 it
could be they ran the batteries in series,,or parallel
media.nl?id=7097&c=288557&h=dfa0e19a839ae9849759
6/2/2011 6:21:04 PM • Eliminator... • Answered on Jun 02, 2011
I have a Keb 12F5 that shows E.EF external fault. How to solve it please?
It appears to be something to do with this https://www.google.com/search?q=keb+12f5+that+shows+E.EF+external+fault 7.13.1.6 External fault With Pn.04 "Ext. fault input selection", one or more digital inputs can be programmed which can trigger the error "31: ERROR! External input" (E.EF). With Pn.03 "E.EF stopping mode" , the response of the inverter to the digital input is defined. With Pn.65/ bit 1 "2: Pn.04 = E.UP https://www.keb.su/doc/Instrukciya%20F5-A_E_H%20ver.4.0%20(ang.).pdf ..
2/27/2024 6:55:25 AM • Electronics -... • Answered on Feb 27, 2024
How do I connect my laptop to the TV?
Back in 2014 it wasn't so easy. Laptop with an HDMI port and a smart television with HDMI. ..
2/27/2024 6:47:57 AM • Electronics -... • Answered on Feb 27, 2024
2answers
I have an Emerson Quiet Kool Rooftop R/V air
I have a quiet cool roof top air conditioner and am looking for parts for it.
2/9/2024 5:25:36 AM • Electronics -... • Answered on Feb 09, 2024
Istar x 20000 USER MANUAL
Help in the link, but the one good site doesn't like my Ad Blocker! https://www.google.com/search?q=Istar+x+20000+USER+MANUAL ..
12/23/2023 11:37:12 PM • Electronics -... • Answered on Dec 23, 2023
Eliminator MotoMaster  Mobile Power Inverter 175 W Logo
Popular Tags
10 questions posted
Top Eliminator Electronics - Others Experts
Ngoro
Aron
Steve Pack
Steve Pack
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Eliminator Electronics - Others
Most Popular Question
need replace cigarette lighter plug
  • Electronics - Others
