20 Most Recent Grundfos UP15-10B5/ATLC 1/25 HP Recirculator Pump with Timer, Li Questions & Answers
Grundfos circulating pump is not working
Troubleshoot resources: http://waterheatertimer.org/Water-heater-recirculation-system.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/27/2014 1:34:31 AM • Grundfos... • Answered on Aug 27, 2014
Grundfos um 15-10 b5
8/27/2014 12:13:13 AM • Grundfos... • Answered on Aug 27, 2014
Grundfos um 15-10 b5 replacement
http://waterheatertimer.org/Water-heater-recirculation-system.html Contact grundfos? Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/27/2014 12:12:53 AM • Grundfos... • Answered on Aug 27, 2014
Grundfos selectric 15-30
8/27/2014 12:11:35 AM • Grundfos... • Answered on Aug 27, 2014
3answers
MY GRUNDFOS 15-50 SELECTRIC PUMP HAS SIEZED IVE
There are rebuild kits for this pump from Johntone Supply or Grainger Supply as well as others. A rebuild would be less then a complete new pump
10/20/2011 8:35:33 PM • Grundfos... • Answered on Oct 20, 2011
My pump is making a
Hi jrfhome...
Look for anyway to bleed the air out of your system.
1...Remove a hose or fitting on the downstream side of your pump,and turn on the pump to discharge the air from the pump impeller.
2...You can force water thru the pump by hooking to the suction side of the pump with a garden hose to prime it... using the garden hose and house pressure to flush out the air from the pump bowl.
3...Look all over the highest part of the pump for some sort of screw, plug, etc to remove or loosen to let the air out of the system to prime the pump.
9/14/2011 4:34:37 PM • Grundfos... • Answered on Sep 14, 2011
I've had my Grundfos Up1510SU7P
It sounds like thermostatic operation is not working.
I cannot offer specific repair, but can offer resources
1) Grundfos service options and warranty information + local distributor of parts and service center finder:
http://www.grundfos.us/web/homeus.nsf/Webopslag/OMAT-5S7J7X
2) Terminal strip and capacitor replacement does not show UP1510SU
http://www.us.grundfos.com/Web/Download.nsf/Pages/F3A9576228BA79AF0825691A006D2D0F/$File/Luptl028.pdf
3) Open following link for recirculation system resources including some manuals, but I don't have your exact manual.
I can see your product on following link
http://www.houseneeds.com/shop/plumbing/recirculators/waterrecirculatorindex.asp
4) Recirculation systems operate 2 ways: with thermostat or timer.
Thermostat is supposed to turn off circulation when water reaches 100 degrees approx.
Until thermostat is repaired, you can work around problem by moving slide switch to TIMER and set timer to run intermittently so temperature at faucet is moderated.
5) Adjust temperature at water heater
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
6/1/2011 8:30:01 AM • Grundfos... • Answered on Jun 01, 2011
After replace the cold water
Many times when pipes are worked on, the work loosens sediment that was built up in the pipe.
Sediment is probably why cold water line was replaced.
That's why faucet aerators get clogged up after pipes are worked on.
It sounds like your grundfos pump got clogged too.
Immediately unplug the pump so motor is not overheating.
Motors are meant to turn freely and can be damaged when blocked.
Take apart the pipes at grundfos pump and see if you can clean out the line.
If line cannot be cleaned or pump doesn't restart, then the grundfos has to be replaced.
Also look at adjoining pipes and see if there is a clog in nearby elbow, especially where galvanized and copper pipes join..
12/26/2010 9:23:40 PM • Grundfos... • Answered on Dec 26, 2010
My 15-10SU 7p/tlc pump will not run. I am lookimg
It will probably be cheaper to purchase another pump
1/21/2010 12:27:01 AM • Grundfos... • Answered on Jan 21, 2010
HOW TO CONNECT A RANCO ETC=112000-000 TO AN INDIRECT WATER HEATER
The Ranco ETC-112000-000 is a temperature controller commonly used for HVAC and refrigeration applications. To connect it to an indirect water heater, you can use it to control the temperature of the water in the indirect water heater's tank. Here's a general guide on how to do this: Please note: This is a general guide, and it's essential to follow the specific wiring instructions provided in the Ranco ETC-112000-000 user manual and the installation instructions for your indirect water heater. Materials and tools you'll need:
  1. Ranco ETC-112000-000 temperature controller.
  2. Indirect water heater.
  3. Appropriate wiring and electrical supplies (cables, wire nuts, etc.).
  4. Screwdrivers.
  5. Wire strippers and crimping tools.
  6. Electrical tape.
  7. Safety equipment (gloves, goggles, etc.).
Steps to connect the Ranco ETC-112000-000 to an indirect water heater:
  1. Read the Manuals: Before starting, thoroughly read the user manual of the Ranco ETC-112000-000 and the installation manual of your indirect water heater. This will ensure you understand the specific requirements and wiring diagrams for your equipment.
  2. Turn Off Power: Ensure the power supply to the water heater and the Ranco controller is turned off at the breaker box to prevent electrical accidents.
  3. Mount the Controller: Mount the Ranco ETC-112000-000 controller in a suitable location, typically on a nearby wall or control panel, within easy reach. Make sure it's securely fastened and level.
  4. Wire Connections:
    • Connect the power supply wires (usually 120V or 240V AC) to the Ranco controller following the wiring diagram in the manual. Typically, you'll have two power wires: one for Line (L) and one for Neutral (N).
    • Connect the load wires from the Ranco controller to the electrical terminals on the indirect water heater that control the heating element(s). Refer to the water heater's manual for the correct terminals.
    • Make sure all wire connections are secure using appropriate connectors (wire nuts, crimps) and cover them with electrical tape to prevent any exposed wires.
  5. Sensor Placement: Install the temperature sensor (usually included with the Ranco controller) into the water heater tank. Ensure the sensor is in contact with the water, as it will measure the water temperature.
  6. Power On and Set Parameters: Restore power to the Ranco controller and the water heater. Configure the Ranco controller according to your desired temperature settings and control parameters. Refer to the Ranco manual for specific instructions on programming the controller.
  7. Test and Monitor: Once everything is connected and set up, test the system to ensure it's functioning correctly. Monitor the water heater's temperature to make sure it maintains the desired level.
  8. Final Check: Double-check all connections and ensure there are no loose wires or exposed connections. Secure the wiring neatly to prevent accidents or damage.
9/2/2023 5:07:16 PM • Grundfos... • Answered on Sep 02, 2023
I have a catchment water system using a jps2-a grundfos pump. Not pumping. Where do I begin to troubleshoot?
Check the breaker. Check the reset on the motor. Wiring connections. If you have power to the motor & motor doesn't work...you need new motor.
10/24/2019 7:29:11 PM • Grundfos... • Answered on Oct 24, 2019
With a recirculation pump, can I remove the motor housing and impeller to replace, or do I have to remove the entire unit?
Normally you can just replace the motor with out changing the entire unit. A new gasket should come with the new motor.
10/24/2019 7:26:07 PM • Grundfos... • Answered on Oct 24, 2019
Grundfos up 15-14b is very noisy
Replace it.
3/17/2019 8:09:58 PM • Grundfos... • Answered on Mar 17, 2019
My grundfos hot water circulator works great. how often should I set it to circulate the hot water, ever hour, before morning shower or evening shower.
Last one I installed, I used a PIR sensor to control it, so that whenever someone walked towards the bathroom or kitchen, the pump will start up and run for 15 minutes. It really depends how often you use hot water - if only certain times of day, then it would be wasting power to run the pump, and heat loss from the pipes (unless very well insulated). If you have a regular pattern of use, then you could use a timer/programmer as you would on your normal hot water or heating. If your piping is plastic, then don't run pump continuously, as some plastic piping is not recommended for continuous circulation at normal hot water temperatures.
10/23/2017 7:08:41 PM • Grundfos... • Answered on Oct 23, 2017
2answers
Need to find a user manual for a Grundfos pump I91340615 P10733, Type CH2-30
ManualsLib.com and enter grundfos pump ch 230 in the search area. Make sure to enter with the proper spacing.
10/21/2017 6:04:31 PM • Grundfos... • Answered on Oct 21, 2017
Hi I have a Grundfos pump that heats radiators fine but not the hot water...checked the small spindle and is spinning fine...
Sounds like the diverter valve is not working. In order to heat the hot water, it needs to direct the circulating water to the heat exchanger rather than the rads.
9/21/2017 7:15:30 AM • Grundfos... • Answered on Sep 21, 2017
Grundfos UP15-10B5/ATLC 1/25 HP  Recirculator Pump with Timer, Li Logo
9 questions posted
Top Grundfos Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Grundfos Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Grundfos Hardware & Accessories
Most Popular Question
grundfos 15 50 selectric pump siezed ive
  • Hardware & Accessories
