20 Most Recent Aube Technologies Aube 7-Day Programmable 40-500w Light Timer Switch Questions & Answers
Noma tc-1 instructions
How do i reset and set a noma tc-1 outdoor timer? Thanks
12/5/2020 10:18:56 AM • Aube... • Answered on Dec 05, 2020
L33C-A noma timer instructions
There is a range of answers on fixya for this question already, and some of the links provided, for example http://waterheatertimer.org/Woods-timers-and-manuals.html may help you find an applicable set of instructions. It appears the company that makes these doesn't have a formal Web presence, and recommends 'you contact the place of purchase' for help (or support material) if you need it. The owner's manual ... if you can find it ... had an 800 number to call for advice; I've had no luck in finding an online copy or even a link containing it, but you might Google if desperate. From what I see, you press the up arrow until something like "Prog 1" is displayed, then set days and times following prompts. This is similar to many designs of home 'smart thermostat' and perhaps uses the same control logic.
4/10/2019 10:34:59 PM • Aube... • Answered on Apr 10, 2019
How to set up timer for model sto1c
http://waterheatertimer.org/ST01C-program.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/21/2014 8:46:54 AM • Aube... • Answered on Oct 21, 2014
Instructions
Check wiring:http://waterheatertimer.org/Aube-timers.htmlAdd a comment and describe the timer you have, and include if this is new timer, or timer that stopped working.Also add if you are connecting for single pole or 3-way.Be aware that some aube timers are not compatible with CFL, and work with incandescent only, and require minimum load wattage.Better choice is ST01C timerhttp://waterheatertimer.org/ST01C-program.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5/8/2013 1:18:46 PM • Aube... • Answered on May 08, 2013
The timer no longer working. I can only turn it on
You posted under Aube in-wall timer.
If this is not your timer, add a comment.
Aube timers have a rechargeable battery that runs timer functions, and timer does not require 120 volts from circuit.
OK, I wrote to Aube about low temperatures affecting their battery.
Aube said, the battery is good down to freezing, and probably lower.
Lower temperatures cause display to slow down and not function, which means timer programs will not work when timer is exposed to cold temperatures.
Manual override would still work, but not programming or display.
So if timer is NOT located inside warm house, for example timer located in unheated garage or shed, then timer will not function in cold temperatures.
That being said, Aube battery is rechargeable.
Battery is not replaceable.
If Aube battery has gone bad, then timer is not repairable.
Intermatic ST01C and EJ500 in-wall timers are also battery operated. Intermatic ST01C and EJ500 battery can be replaced.
Almost all plug-in type timers also have a rechargeable battery that is not replaceable.
Several in-wall timers do not require a battery, but they need power from electric circuit.
To see these timers, plus description how to wire this type of timer:
http://waterheatertimer.org/Programmable.html#Aube
1/21/2013 1:56:07 AM • Aube... • Answered on Jan 21, 2013
2answers
Where can I buy the Aube 7-Day Programmable
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
11/22/2012 7:24:00 AM • Aube... • Answered on Nov 22, 2012
2answers
Need instructions for Aube by Honeywell 7-day
pdf is at
www.smarthome.com/4256W/Aube-7-Day-40-500W-Timer-White-TI032-3W/p.aspx
11/22/2012 7:00:30 AM • Aube... • Answered on Nov 22, 2012
Where can we purchase Aube 7-Day Programmable
9/28/2011 10:37:13 PM • Aube... • Answered on Sep 28, 2011
I have an Aube 3
Utilitec can only replace single-pole switch.
Open following link for typical Utilitec single-pole wiring:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Aube timer has internal battery that runs clock mechanism and does not require neutral wire.
The Aube battery lets timer replace single-pole or 3-way switch.
Utilitec timer does not have battery, so clock mechanism requires neutral wire, just like plugging in electric clock.
Without battery, timers like Utilitec can only replace single-pole switch.
Open following link to see list of timers that can be used for 3-way:
http://waterheatertimer.org/Aube-timers.html#3-way
When installing 3-way timer, the timer replaces one 3-way switch but other 3-way switch remains.
The remaining 3-way is rewired to accommodate the specific timer being used.
SOME brands of timer cannot replace either 3-way switch, but instead can only replace the 3-way that receives hot wire from breaker: Read manual before selecting timer.
Note: Battery-operated timers can be used for 3-way application, but cannot operate in cold environment.
8/14/2011 12:03:22 AM • Aube... • Answered on Aug 14, 2011
We had a aube timer
Aube/Honeywell timers have internal rechargeable battery that powers the display.
Battery is not replaceable. Plus the electronics inside timers are susceptible to power surge.
Without the display, timer cannot be used.
These timers come with standard 1 year limited warranty.
7/11/2011 6:37:07 AM • Aube... • Answered on Jul 11, 2011
How do you program this . I had to reset and do
Timer is not identified.
You posted under Honeywell/Aube timers:
Open following link to identify product and download manual:
Add a comment if more help is needed and include timer model number and where the manual or wiring is confusing.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
6/11/2011 6:29:56 AM • Aube... • Answered on Jun 11, 2011
Lost programming instructions and need
Open following link to identify timer and download manual
Add a comment for more help
Upvote the help.
6/6/2011 10:47:48 PM • Aube... • Answered on Jun 06, 2011
Lost the instructions T1032-33-34-35 can we get
http://waterheatertimer.org/pdf/Aube-T1032-timer.pdf
Aube is a Honeywell product I believe:
The timer seems revolutionary for not requiring a Neutral wire, yet requires no battery either.
Advantage: No more confusing wiring. Simple 7-step programming.
If old switch has 2 wires, the Aube changes to 2-wire application
If old switch is 3-way, the Aube changes to 3-wire application, the only major change is jumper on other 3-way switch
Timer replaces ordinary wall switch:
Timer replaces 3-way switch
5/22/2011 5:09:01 AM • Aube... • Answered on May 22, 2011
Have model T1 032A programmable 3 way mfg 11-06
Open following link to identify timer and download manual:
The reset button is small round button and can be pushed with toothpick or paper clip.
If reset doesn't restore timer, then timer is probably shot.
Also check all breakers to make sure one isn't tripped.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
3/22/2011 2:14:48 AM • Aube... • Answered on Mar 22, 2011
I lost the instructions for my Aube origrammable
3/22/2011 2:13:48 AM • Aube... • Answered on Mar 22, 2011
Lost manual for Aube 2400 watt timer
3/22/2011 2:07:34 AM • Aube... • Answered on Mar 22, 2011
Looking for instruction manual for
I have extensive files on timers.
I don't recognize Noma 052-8814-2
Noma is an old Intermatic name that is now used by many companies to describe many models of timers.
There is wide bleed-over of timer names and designs across different manufacturers.
1) Please add a comment and post photo of your timer so I can match with existing manuals.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Add a comment and describe timer in detail so I can match up a manual if possible.
3) Open following link to see all Noma-Woods timers I have on file.
3/22/2011 2:05:57 AM • Aube... • Answered on Mar 22, 2011
I have the lightswitch timer.
Most in-wall timer manuals suggest re-setting timer to restore functionality.
If re-set does not restore timer, then timer is probably bad.
To download Aube manuals:
http:///waterheatertimer.org/Aube-timers.html
There are 3 things to remember about timers.
1) Line noise and bad wiring can affect electronics inside timer.
Buy cheap circuit analyzer at home center and test nearby outlet that is on same circuit breaker.
2) Aube timers have internal rechargeable battery and cannot be exposed to temperatures below freezing
3) Industry standard is 1 year limited warranty on timers.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
3/22/2011 1:55:16 AM • Aube... • Answered on Mar 22, 2011
Lost power and need to
Aube timers have back up battery that recharges after power resumes.
Battery should hold programming during outage.
If battery does not charge, then screen doesn't light up and programming not possible.
Aube makes several timers.
Aube timers and manuals posted at following link.
If you have different timer, add a comment
11/16/2010 8:10:40 AM • Aube... • Answered on Nov 16, 2010
Aube Technologies Aube 7-Day Programmable 40-500w Light Timer Switch  Logo
29 questions posted
Top Aube Technologies Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Aube Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Aube Technologies Hardware & Accessories
Most Popular Question
aube timer
  • Hardware & Accessories
