20 Most Recent Kobo Arc Questions & Answers
My kobo wont turn charge and turn on
Broken psu connector or moethboard junk it its not cost effective to repair.
12/18/2020 6:52:54 AM • Kobo Arc • Answered on Dec 18, 2020
Kobo not accepting a charge
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges. If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up. In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes. You are much better off recharging when 50% depleted than using it up til your product stops. L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
12/11/2020 6:30:34 AM • Kobo Arc • Answered on Dec 11, 2020
My kobo wont open the book, keeps loading but does not open
Does your Kobo turn off and on normally? Or is it stuck loading the book and totally not responding? If so, reset your Kobo. Look on the bottom edge of the Kobo - see the little pinhole? Stick a paper clip into there until you feel it push against a little switch. Remove the paper clip. Is the Kobo working, but simply can't open a book? If it's only affecting a particular book, try deleting it and downloading it again.
12/10/2020 6:21:24 AM • Kobo Arc • Answered on Dec 10, 2020
Hi, i have a kobo arc, and recently it has stopped working. The light stays on, and every time i go on it, it freezes and i cant do a thing with it. not even turn the screen off, or do the volume or
Hold the power and volume button at the same time till u get a box and a tool thing on your screen the by using the volume down go to wipe data press power button to ok then go down to yes with volume down key and press the power button to ok yes then will reset your tablet like when first got it
3/5/2018 1:21:22 AM • Kobo Arc • Answered on Mar 05, 2018
How do i delete trash forever
Go to your trash folder select mark all then click delete forever. Then empty your trash as normal. This works in easy mail as well as web gmail
8/3/2016 10:01:15 PM • Kobo Arc • Answered on Aug 03, 2016
Kobo problems
If the books have been loaded from Kobo, you can go to their site and load them again (for free). If not, you would have to get them again from other sources and may have to pay for them again.
8/27/2015 9:33:06 PM • Kobo Arc • Answered on Aug 27, 2015
How do I delete my contacts?
Go to a contact in the Contacts app and click the menu button. Click delete.
5/2/2015 6:14:54 PM • Kobo Arc • Answered on May 02, 2015
How do I brighten the screen so Ican read outside
Settings> Display> Brightness
4/17/2015 9:18:32 PM • Kobo Arc • Answered on Apr 17, 2015
Locked out do not know the password
Keep guessing until "Forgot Password" comes up; login with you Google Account and voila
4/17/2015 9:15:10 PM • Kobo Arc • Answered on Apr 17, 2015
How to delete some contacts in the Kobo arc
Simply go to the Contacts app, click a contact and press Delete. If there is no delete, it might be under the menu button, which is 3 dots
4/17/2015 9:13:34 PM • Kobo Arc • Answered on Apr 17, 2015
Download kobo arc 7 instruction manual
http://download.kobobooks.com/magento/userguides/downloads/KoboArc7/koboarc7_userguide_en.pdf
3/17/2015 3:14:29 PM • Kobo Arc • Answered on Mar 17, 2015
Why are cookies preventing me from setting up Facebook?
https://www.facebook.com/help/212354552120351
3/17/2015 2:47:09 PM • Kobo Arc • Answered on Mar 17, 2015
Kobo Arc Logo
230 questions posted
Top Kobo Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Kobo Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Kobo Tablets & eReaders
Most Popular Question
  • Tablets & eReaders
