20 Most Recent
Northstar Gas Powered Wet Steam & Hot Water Pressure Washer 3000 PSI Questions & Answers
Will not build presure at
run some oil in inlet/outlet/or/oil then connect hoses back what is going on is when you run it then store it the seals dry up keep it oiled when storing.
Coleman pressure washer won't turn over.
If your pressure washer doesn't have an electric start, then leaving the switch in the on position would have done no harm. (It might have done no harm even if it does have electric start, but that depends.) Your most likely problem is gummy gas residue. Have you tried a spray starting aid like "instant start"? If you get some firing with that, but does not keep running, then your gas supply is clogged, probably at the needle valve that operates via a float. If it keeps running, then you may have cleared the clog already. In any case, be sure to use a gas preservative like "Sea Foam" or similar to prevent this headache in the future.
If you found this useful, please vote.
Thanks.
