20 Most Recent Lutron ELECTRONICS S-1000H-LA SKYLARK SLIDE DIMMER SP LIGHT ALMOND Questions & Answers
There's a lot of stuff here, and you may need to clairfy a few details to get to your exact answer. There are a couple of different products that Lutron makes that have the combination fan & light combo, and you may need some help figuring out which one it is. However, the details of this are simple enough that you should be able to simply call their tech support number and have someone walk you through it. They're at 1-800-523-9466 and they're available 24/7.
I'd try to give you a more thorough answer but trying to walk someone throught he wiring combinations on-line like this tends to add more confusion than necessary.
Lutron ... | Answered on Oct 19, 2010
If your wallplate is hot, that is a sign of trouble, and possible electrical fire. That dimmer is not made for the load, or it is going bad.
Turn off the dimmer immediately. Do not use the dimmer at all. Replace with a wall switch until you have the correct dimmer.
Each dimmer is rated for Watts. Ordinary electrical switch is rated by amps. Ordinary 15 Amp electrical switch can handle up to 1400 Watts. This means 14 - 100 watt bulbs.
Dimmers are usually not rated for 1400 Watts. They have 500-600 Watt rating. Look at the side of your dimmer for Wattage information that is usually printed on dimmer.
Heavier-duty dimmers cost more and can carry more wattage. Some dimmers carry up to 1800 watts. These kinds of dimmers have aluminum heat sink visible right on the face of dimmer.
In any case, your dimmer is an electrical fire hazard and should be replaced. Add up total wattage of your lights, and read new dimmer package when buying.
Up-vote if this information is helpful. Thanks for the feedback.
Lutron ... | Answered on Oct 15, 2010
I had the same problem. You just have to push the slider down a bit harder. It will click and will be completely off.
Lutron ... | Answered on Jun 28, 2010
What is the dimmer rated for? Your load on the track appears to be 200 watts. A standard dimmer will burn out, you need to look on the dimmer to see what it is rated for. Did it run hot with the dimmer before you had this problem? They make dimmers for higher wattage that will do the job for you.
Lutron ... | Answered on Oct 09, 2009
I take it you don't want to just remove the upstairs 3 way switch and wirenut the 3 wires together and put a blank cover plate over the box<?>.
Need to know more info. Does the upstairs box have 3 wires only? If no, then likely you will not be able to abandon the upstairs switch box as it will need to remain as an active junction box. If yes, then it becomes a rather lengthy procedure (textual). I'll sketch it out but need an answer the number of wires in upstairs box.
Comment below so I may assist further.
Lutron... | Answered on Apr 11, 2019
There are a lot of DIVA models and you did not post the model number. There are multple configurations and wiring methods.
Lutron... | Answered on Feb 09, 2019
You might look to see if the outlet is GFI protected. It is possible the GFI (Ground Fault Interrupter) tripped and needs to be reset.
If so, push the red button (reset button) firmly until it stays down (pushed in). If it does not stay closed, replace it.
Also check your light bulb fed by "the switch that does not work", to make sure it did not burn out.
Your switch could be good, but the bulb bad.
If your light switch is not on a GFI circuit and both Lutron switches are fed by one breaker, get a volt-ohm meter, set it to the volts in a voltage range to read house hold voltage (around 121 volts), and check to see that both switches are receiving 121 volts. Usually you measure with the black probe touching a white (neutral) wire, while the black wire is usually the wire that is in series with the lamp. A black wire may come into the switch and leave as a black wire going to the bulb. If you do not have full voltage reaching your switch, you may have a wiring problem where a wire is no longer making good contact. If you are not sure about how to test with a volt meter, search on your tube for further explanations on how to test to see if a light switch is good.
Lutron... | Answered on Dec 31, 2018
Not sure if you can just splice the extra wires together. The ballast information is what matters converting to just on-off, not the finger switchswitch
Lutron... | Answered on Dec 01, 2018
Let's start at the beginning please. You have a source cable fed into an overhead outlet box or to a switch outlet box on the wall? This is critical because it tells me what kind of arrangement you actually have.
If the source is in the ceiling, then you are using switch loops and the wiring gets tricky because you have to "re-task" the Neutral (White) wire (Assuming you are here in the U.S.A.) that goes to the switch because it will become the feed to the wall switch.
However, is the feed is at the switch, then it is much simpler. Please let me know what you have in the form of wiring.
Also as an FYI, if you are using special switches, you may have to have equipment grounding conductor present at the switch. The electrical code no longer allows the use of a Neutral (White) conductor as a grounding conductor.
Lutron... | Answered on Nov 27, 2017
You could do that but it would not be up to the electrical code requirements. Take the old one out and remove the wire nuts and put the new one in. There should be a ground wire stuffed in the box somewhere. Unless the house is really old. You connect the ground wire to the bare ones in the box.
Lutron... | Answered on Nov 21, 2016
Led? Normal.
Lutron... | Answered on Sep 02, 2016
Hmmm a lot of rope lights are just mini xmass tree lights inside a plastic tube. If one of the bulbs burns out for that section the it takes the whole section out. Sounds like it's time for a new led rope light.
Often led s hesitate even with single pole switch. It's probably not the dimmer. Led s get powered from a transformer inside the fixture and it just takes a second for them to get going. I've found its not consistant. The same two recessed lights have different start up times.
Lutron  ELECTRONICS S-1000H-LA SKYLARK SLIDE DIMMER SP LIGHT ALMOND Logo
6 questions posted
Top Lutron Electrical Supplies Experts
jdthefixer
Craig Butler
Craig Butler
mikenearman
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lutron Electrical Supplies
Most Popular Question
lutron dimmer not dimming but off works
  • Electrical Supplies
