20 Most Recent Lutron GL-1000 Glyder Single-pole 1000 Watts Slide-to-off Incandescent Dimm Questions & Answers
How connect 3 way dimmer.I can connet two 3 way
No, you can only use one dimmer, the other switch has to be a regular three-way switch.
2/2/2011 2:43:23 AM • Lutron GL-1000... • Answered on Feb 02, 2011
Problem with 1000 w sliding dimmer switch; lights
I think you need a provide a little more information in order for there to be a possible solution. I'm particular confused by your use of the term "eventually" - these are analog dimmers, there are no "smarts" involved with this products, so I don't get how it would magically turn itself on to a higher brightness. Regardless, you will be able to get a much quicker answer by just calling Lutron directly. Their tech support number is 1-800-523-9466, they're available 24/7, and it won't cost you anything. They can help you diagnose whether its something related to installation or whether the product has simply hit the end of its life, and they can probably assist you with gettting a replacement as well.
1/11/2011 2:15:47 PM • Lutron GL-1000... • Answered on Jan 11, 2011
2answers
Lutron Dimmer - Maestro Desert Stone color is discontinued
You're in a difficult position for which I see few options --- none of them ideal. Short of replacing all your switches and wall plates in a matching color of your choice, a cheaper option might be to find a satin spray paint in or near-enough to your color and gently spraying the new dimmer(s) to match. Alternatively, Eaton makes LED dimmers in "Desert Sand" (but whether their Desert Sand looks anything like Lutron's is beyond me).
5/17/2023 9:34:50 PM • Lutron... • Answered on May 17, 2023
Aquadyne pool controls
Which one? My eyes are poor and I cannot see that far.
10/2/2021 3:21:32 AM • Lutron... • Answered on Oct 02, 2021
2 black wires on my light switch
That is normal. I assume the two white wires are connected together in the box.
10/2/2021 3:16:46 AM • Lutron... • Answered on Oct 02, 2021
Two 3 way dimmers controlling one light
This is a no-no unless they are specifically designed to do this.
10/2/2021 3:16:07 AM • Lutron... • Answered on Oct 02, 2021
Yellow jumper wire
The directions tell you where to connect it. My eyes are poor and I cannot see what you have!
10/2/2021 3:13:53 AM • Lutron... • Answered on Oct 02, 2021
CAN NOT SHUT OFF LUTRON LIGHT. MOTION DETECTOR LUTRON. I CHANGED BULB NOW IT WON'T TURN OFF NO MATTER WHAT I TRIED.
It sounds like you blew the triac (the electronic switch) in the light. You will need to get a replacement module or a new light. Sometimes lightning will cause this. If it was a tungsten lamp they can have a large current surge when it fails.
10/2/2021 2:49:10 AM • Lutron... • Answered on Oct 02, 2021
4 way diagram for lutron Radio RA2 RRD ANF that has 2 other RD RD switches and controling 3 ceiling fans
The only device rated for a motor load is the RRD-8ANS and itequires a neutral connect.
To clarify you have a gang of 3 fans you want to control from more than 2 locations (3 or more existing wall switch boxes)?
1/12/2020 3:08:35 PM • Lutron... • Answered on Jan 12, 2020
12 V halogen track (8 bulbs; replaced withLED); turned on Lutron dv600p dimmer; lights lit & frying sound; then off. all bulbs still good. Differential diagnosis for transformer vs Lutron problem?
Halogen work with AC or DC voltage ... 12 volt LED bulbs are DC. Check that transformer delivers DC, or buy 100 watt IP67 LED driver. Keep in mind the lutron DV-600 is rated for incandescent and halogen loads, and may not function as expected when connected to inductive load like transformer or driver.
10/27/2019 3:25:24 AM • Lutron... • Answered on Oct 27, 2019
I have a 3-way switch in an old house that has three black cloth-covered wires attached. the second switch is up the stairs and I would like to remove completely and cover the hole.
I take it you don't want to just remove the upstairs 3 way switch and wirenut the 3 wires together and put a blank cover plate over the box<?>. Need to know more info. Does the upstairs box have 3 wires only? If no, then likely you will not be able to abandon the upstairs switch box as it will need to remain as an active junction box. If yes, then it becomes a rather lengthy procedure (textual). I'll sketch it out but need an answer the number of wires in upstairs box. Comment below so I may assist further.
4/11/2019 5:00:25 PM • Lutron... • Answered on Apr 11, 2019
2answers
Replacing an old lutron skylark dimmer switch with new lutron Diva in a double box with another switch that controls outlet. the breaker keeps tripping when i flip it back on.
There are a lot of DIVA models and you did not post the model number. There are multple configurations and wiring methods.
2/9/2019 6:59:12 PM • Lutron... • Answered on Feb 09, 2019
How do I fix my light switch? I checked my circuit breaker and that's working. I replaced the switch with a new switch and it still doesn't work.
You might look to see if the outlet is GFI protected. It is possible the GFI (Ground Fault Interrupter) tripped and needs to be reset. If so, push the red button (reset button) firmly until it stays down (pushed in). If it does not stay closed, replace it. Also check your light bulb fed by "the switch that does not work", to make sure it did not burn out. Your switch could be good, but the bulb bad. If your light switch is not on a GFI circuit and both Lutron switches are fed by one breaker, get a volt-ohm meter, set it to the volts in a voltage range to read house hold voltage (around 121 volts), and check to see that both switches are receiving 121 volts. Usually you measure with the black probe touching a white (neutral) wire, while the black wire is usually the wire that is in series with the lamp. A black wire may come into the switch and leave as a black wire going to the bulb. If you do not have full voltage reaching your switch, you may have a wiring problem where a wire is no longer making good contact. If you are not sure about how to test with a volt meter, search on your tube for further explanations on how to test to see if a light switch is good.
12/31/2018 6:23:00 AM • Lutron... • Answered on Dec 31, 2018
How can you replace a Lutron Model FD-12 Flourescent dimmer switch with a simple on off switch?
Not sure if you can just splice the extra wires together. The ballast information is what matters converting to just on-off, not the finger switchswitch
12/1/2018 8:50:35 AM • Lutron... • Answered on Dec 01, 2018
First, I have power running thru a switch box. All
Let's start at the beginning please. You have a source cable fed into an overhead outlet box or to a switch outlet box on the wall? This is critical because it tells me what kind of arrangement you actually have. If the source is in the ceiling, then you are using switch loops and the wiring gets tricky because you have to "re-task" the Neutral (White) wire (Assuming you are here in the U.S.A.) that goes to the switch because it will become the feed to the wall switch. However, is the feed is at the switch, then it is much simpler. Please let me know what you have in the form of wiring. Also as an FYI, if you are using special switches, you may have to have equipment grounding conductor present at the switch. The electrical code no longer allows the use of a Neutral (White) conductor as a grounding conductor.
11/27/2017 6:41:36 PM • Lutron... • Answered on Nov 27, 2017
Can I just cut the black wires coming out of old switch and connect with wire nuts to black wires of new switch? And cap off the ground wire from new switch since no ground on old switch?
You could do that but it would not be up to the electrical code requirements. Take the old one out and remove the wire nuts and put the new one in. There should be a ground wire stuffed in the box somewhere. Unless the house is really old. You connect the ground wire to the bare ones in the box.
11/21/2016 12:17:03 AM • Lutron... • Answered on Nov 21, 2016
Lutron GL-1000 Glyder Single-pole 1000 Watts Slide-to-off Incandescent Dimm Logo
2 questions posted
Top Lutron Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
Eric Kalman
Eric Kalman
Level 1 Expert
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lutron Electrical Supplies
Most Popular Question
connect 3 way dimmer connet two 3 way
  • Electrical Supplies
