20 Most Recent
Leviton #L32-06631-WWP White Decora Slide Dimmer Questions & Answers
I attempted to install a slide dimmer yesterday.
The white and the black wires are both hot wires, and the green wire is for earth ground only. The green wire does not belong hooked up to the white wire.
The two black field wires should be attached to one side of the dimmer switch (one of the black wires from the dimmer switch)
The white field wire should be attached to the other side of the dimmer switch (the other black wire from the dimmer switch)
The green wire from the dimmer switch should be hooked up to earth ground only (any un-insulated copper wire that is inside the switch/outlet housing) and if you can not find it attach the green wire to the inside of the light switch outlet housing and be sure that it is attached to metal.
The other hall light switch that you are talking about must be connected inline with that light switch you trying to turn into a dimmer, and it should operate again nomally once you have connected that light switch properly, and if not check for any tripped circuit breakers.
5/17/2010 2:47:49 PM •
Leviton...
Answered
on May 17, 2010
I cannot turn off light that uses a Leviton Cat /no 16400, DHC switch not can i find the receiver box that controls the lights
A Leviton DHC receiver device can look like any other switch or receptacle so if you didn't install it or not provided a map then you'll need to locate it.
Likely the wall switch that originally controlled the light was replaced with DHC device and paired with the 16400 at another location. If you can't identify it, then removing face plates and devices may be the only practical method to locate it.
If your not comfortable with removing devices safely, hire an electrician.
https://www.mc-mc.com/ASSETS/DOCUMENTS/ITEMS/EN/Decora_6375_Catalog.pdf
7/5/2021 2:59:40 PM •
Leviton...
Answered
on Jul 05, 2021
Wiring a leviton 5641 so fan & light turn on separate with red & black wires
the 5641 is a dual switch for three way and single pole. If you want the switches to operate the CF. Connect the power to one of the two screws on the right side as you face the switch. then connect one wire to the screw on the bottom left side. connect the other screw to one of the two screws on the top left. This assumes the Red and Black you mentioned are the switch legs going to the CF.
5/1/2017 3:42:09 AM •
Leviton...
Answered
on May 01, 2017
Wire occupancy sensor to control receptacle
Your description doesn't explain the circuit, the function of the wires or how the switch controls the outlet and whether the switch is a single pole or two-pole switch. Without such details it is difficult to visualise the circuit.
I advise before you go further to test the sensor in a known good and correctly wired outlet using a length of cable and a suitable plug for the outlet. It is possible the unit is faulty. If it functions correctly on test you will need to understand the circuit and the function of the wires before you rewire it to assure success.
4/18/2016 2:23:52 AM •
Leviton...
Answered
on Apr 18, 2016
