20 Most Recent
SIM2 Domino 30 Multimedia Projector Questions & Answers
I have a SIMS Domino 30BS HD Multimedia projector.
Hi. I find that
often in times of bad weather, the HD picture on U-verse can become
unstable like this. Likely they have a small outage from the hurricane
last night. Try calling ATT, or giving it some time. This problem should
rectify itself.
ATT contact information: http://www.att.com/gen/general?pid=1605
It could also be the projector, though. If the signal from your U-verse or Satellite devices is digital, or otherwise not compatible with the projector, this could cause the unstable picture issue. The following is from your projector's manual:
Image is disturbed, unstable or noisy:
- Verify compatibility of video/graphic signals with the technical
specifications of the projector.
- Check the integrity of cables connecting projector to various
sources.
- If the signal source is a terrestrial broadcast (via a VCR) check
that the receiving channel has been correctly tuned in and
that the aerial system is in good working order.
- Should the problem be present with a signal coming from a
video-recorder, ensure that the videotape is an Original "first
generation" copy and in good condition.
- Adjust the VCR's tracking control for optimum picture performance.
Ensure the VCR mode is active in the Picture menu.
Manual for your projector: http://sim2-extranet.com/files/downloads/down-Domino_20_30_21x21_UK_1.pdf
Regards,
D
My picture is unstable with
Welcome to Fixya. I would like to know what do you mean when you say that the picture is unstable? are you using the SIM2 Domino and you connect it to the receiver? How many receiver do you have?
Thanks
How to reset lamp hours on Sim 2 Domino 18
I am not familiar with your brand in particular but they are all pretty much the same. In the menu under settings you should be able to scroll to lamp settings. Under that category or something like that will be where you can reset the hours.
Power fuse keeps blowing, as
There is most likely a short circuit in the power supply unit, or on the main processor board.
You would have to disconnect the cables running from the power supply to the other boards and gradually reconnect them until the problem shows up again. If you have the service manual you could follow the fault finding procedure, but would need to have a lot of experience in electronic fault finding and the correct test instruments.
