20 Most Recent Samsung AS1293L Air Conditioner Questions & Answers
Up down temp keys not
It is possible that the control panel is not reacting to the customer changing the temperature as the processor is not malfuncting.
The circuit of the control panel with the votages in the processor section must be checked.
The crystal oscillator frequency and the in/out data of the processor IC must be checked.
1/26/2015 11:52:00 PM • Samsung AS1293L... • Answered on Jan 26, 2015
Hi I have 1.5 ton samsung split AC. the problem is...
the water comes from the coil, start there make sure there is no obstruction coming out to your condensate line and make sure its properly pitched.
7/17/2014 3:06:51 PM • Samsung AS1293L... • Answered on Jul 17, 2014
Water leaking out the front right edge of the
the window unit should be 'slanted' (just slightly) to the rear so that the condensation water can drain out the back of the unit.
Check and make sure the drain hole is open and not clogged too.
8/9/2011 3:00:22 PM • Samsung AS1293L... • Answered on Aug 09, 2011
3answers
I got a sam sung split A/C while switch on the
just check the gas pressure and gas pressure is ok,may be out door unite is blocked.do the high pressure service
7/21/2011 3:01:10 AM • Samsung AS1293L... • Answered on Jul 21, 2011
Display shows Ch.
Ch is usually followed by another error code if there is a problem with the unit. If you have no other errors this is a reminder to clean the filter that will appear every 366 hours of use. Clean the filter and reset the code by pressing the UP and DOWN temp arrows at the same time until the diplay changes.
Thanks for choosing FixYa,
Kelly
6/27/2011 12:50:26 PM • Samsung AS1293L... • Answered on Jun 27, 2011
Not starting
hi,
Check the room temperature sensor and coil sensor. If any one is faulty the AC will not start after delay.
added the picture of two sensors for your reference.
ok
6/11/2011 9:14:03 AM • Samsung AS1293L... • Answered on Jun 11, 2011
I plug up the unit
There is a short in the unit...
If it is kicking the breaker as soon as you plug it in then there is a good chance that the problem is in the cord...
Anyway the best way to find the problem will be to use an OHM meter and trace down the source of the short...
heatman101
5/26/2011 2:54:36 AM • Samsung AS1293L... • Answered on May 26, 2011
My samsung bio sleep airconditioner
Replace coil sensor, fixed in evaporator coil. Thanks, helpful?
2/7/2011 1:10:27 PM • Samsung AS1293L... • Answered on Feb 07, 2011
Samsung split ac 1.50 ton
E-2 means coil sensor defective. Replace it.
12/7/2010 11:17:30 AM • Samsung AS1293L... • Answered on Dec 07, 2010
I have always believed in Samsung products...in
If you can copy and past your message to the Samsung web site it might get some results. The side you are on is not affiliated with any company. Here's a link.
http://www.samsung.com/us/info/contactus.html
4/23/2010 2:13:42 PM • Samsung AS1293L... • Answered on Apr 23, 2010
Cooling but not heeting,why?
Try adjusting the thermostat to what temperature you want it to go to,
12/17/2009 4:50:17 PM • Samsung AS1293L... • Answered on Dec 17, 2009
IN heeting mode air condentioner not working,why?
this unit has an a/c package combined with an electric heat strip. It utilizes a common fan for both. the fan should still work but not the heat because of a fusable link burned out on one end of the heating element. there is no heat because there is not electicity flowing through the resistor wire.
12/15/2009 4:11:05 AM • Samsung AS1293L... • Answered on Dec 15, 2009
2answers
Rapidly turns on and off
low pressure cut-out is active.unit needs recharging.
10/17/2009 4:36:25 PM • Samsung AS1293L... • Answered on Oct 17, 2009
4answers
Water/condensation is backing up in the bottom of
The drain in the condensate drip pan is clogged. Locate it and clean it out.
Charlie
8/28/2009 1:49:37 AM • Samsung AS1293L... • Answered on Aug 28, 2009
Power Cord Chew Toy
Any qualified electrician will be able to fix it. It shouldn't take more then 1/2 hour for them do to it, and they can even put on a cable that will protect your dog/the cable from biting through again and possibly getting electrocuted. Overall cost should be less then 50 dollars. Check the Yellowpages if you don't know an electrician.
6/5/2009 1:59:48 AM • Samsung AS1293L... • Answered on Jun 05, 2009
Samsung AS1293L Air Conditioner Logo
26 questions posted
Top Samsung Heating & Cooling Experts
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Heating & Cooling
Most Popular Question
display shows ch
  • Heating & Cooling
