20 Most Recent
Maxtor 8E036JO 36G 80PINS SCSI 15K RPM HDD Hard Drive Questions & Answers
Trying to find the jumper
SCSI hard drives and devices have a jumper setting to configure the SCSI ID.
Each SCSI device must have a different ID.
The jumper/s are set for the following positions across 3 pairs of pins
: : : = SCSI ID = 0 no jumpers - usually for the boot hard drive
: : I = SCSI ID = 1
: I : = SCSI ID = 2
: I I = SCSI ID = 3
I : : = SCSI ID = 4
I : I = SCSI ID = 5
I I : = SCSI ID = 6
I I I = SCSI ID = 7
This gives a total of 8 possible SCSI devices on one SCSI controller.
Maxtor External Hard Drive No Power
I assume it is a USB connection? Does it also have a power adaptor or a USB dongle that has 2 USB connectors? If you cannot get it to power up, the only other option to retrieve your data is to take the HD out of the case and connect it to a PC or laptop using a SSD or SATA to USB adapter and see if you can get the PC to recognize it.
I got a new computer and need to install Maxtor on my new machine. How do I do thei?
If you mean the Maxtor disk utility that comes with raw hard drives, it is NOT necessary to install this in order for the drive to work. If the new computer already has an OS on it and is working, what part of the Maxtor utility is it that you think you need? The OS has all the tools you would need to work with the disk. Or you could always download a 3rd party app to do the specific task. If this is regarding an external drive, again the new computer ( and OS) will have whatever tools you would need to work with the disk. In fact you should only have to plug the external disk into the USB port and the new computer will find it and ask how you want to use it, etc. The Maxtor disk utilities that came with raw drives is pretty much obsolete when used with a current Windows or Mac OS.
