20 Most Recent Black & Decker Dewalt No.DW505 Heavy Duty Vsr Dual Range Hammerdrill 7.8A Questions & Answers
Need wiring diagram for dw505-2 trigger
Here is your parts diagram just in case you need it.
http://www.ereplacementparts.com/dewalt-dw505-type-hammer-drill-parts-c-1009_9661_2281.html
And here is the number to a factor tech which could answer your question on trigger wiring. There is no diagram available but, I'm sure a tech will get you up and going.
(702)889-6025 ask to speak to a tech.
3/31/2009 3:25:53 PM • Black & Decker... • Answered on Mar 31, 2009
Can my black & Decker 3/8 drill model No.7143 go in reverse
The motor does not go in reverse.
12/10/2023 8:11:01 AM • Black & Decker... • Answered on Dec 10, 2023
Where can I get a battery for Black & Decker Drill CD 1000?
This will be a suggestion...but for mine I bought two 18650 LiFePo4 cells (3.7V each) and replaced the original NiCd Batteries. It has been working for many years now, since the original batteries expired and stop working in 2002 (I bought the CD 1000 back in 1994!!!!!). You have to use a special charger for the new ones but they stay charged a lot more and the drill has more torque.
8/5/2023 1:54:00 PM • Black & Decker... • Answered on Aug 05, 2023
Black & decker 40 volt battery is put on charger it flashes the green light twice then the red light flashes continueously qwhat could be the problem
hi, have you seen this ? https://support.blackanddecker.com/hc/en-us/articles/360012702998-If-my-battery-is-not-charging-what-can-I-try-#:~:text=If%20your%20battery%20is%20not,charger%20to%20try%20charging%20again. Now i don't think that's the issue , it more likely the cells won't take a charger or the bms electronic board has failed , with those battery packs it can be a electronics problem or a failed cell , One thing you might want to check is the actual connection to the battery pack..i seen a issue here where there is a bad connection , the charger won't charge regards Rob
3/13/2023 3:13:19 PM • Black & Decker... • Answered on Mar 13, 2023
2answers
Black + Decker Roto-Bit Storage Screwdriver 4V BDCS50. OK to leave on charger?
With that being said, be advised that leaving the screwdriver on the charger after fully charged may overcharge it and also shorten its battery life. Therefore, it is recommended to unplug the unit from the charger after charging.
2/25/2023 7:51:31 PM • Black & Decker... • Answered on Feb 25, 2023
Need switch for B&D drill. Cat # 1065-09 ETRM 254A
fixya doesent sell products repair shop or online order
1/10/2022 1:04:04 AM • Black & Decker... • Answered on Jan 10, 2022
Does a Black & Decker 3/8 variable speed drill number 7120 go clockwise
Has to so it can drill the hole .
9/16/2021 2:59:22 PM • Black & Decker... • Answered on Sep 16, 2021
Replacement of Chuck BLACK & DECKER VSR 1200
If you open the jaws as large as they will go, there is a screw for fixing. It has a left hand thread!
7/4/2021 7:06:35 AM • Black & Decker... • Answered on Jul 04, 2021
2answers
How to remove a chuck from Black & Decker VPX1212 drill
Open the chuck as wide as it will open and look inside to see what type of screw/bolt it uses then using the correct tool insert it into the chuck and undo the bolt/screw, usually it will have a left hand thread so to unscrew it needs to be rotated in a clockwise directions, hold the chuck tightly but dont use excessive force if this does not work then try unscrewing it in the opposite direction, at all times be firm but like I mentioned earlier dont use excessive force.
11/23/2019 3:47:34 PM • Black & Decker... • Answered on Nov 23, 2019
2answers
Como desarmar un black & decker power driver 9076
Good day Can you please supply more information Thank you
5/29/2019 4:13:01 AM • Black & Decker... • Answered on May 29, 2019
3answers
Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
1/30/2019 3:13:04 AM • Black & Decker... • Answered on Jan 30, 2019
Can anyone tell me what the various controls on a Black & Decker SR 910 RT Hammer drill do?
there's a button behind the trigger for locking the trigger at full speed. there's a button above the trigger for clockwise and counter-clockwise rotation. there's a button on the top for hammer mode or regular mode. Hammer mode is for concrete, it basically makes the drill bit hammer in turning the concrete underneath it to dust as opposed to cutting with a sharp edged drill bit for regular stuff like wood or metal. If yours has numbers those are for torque settings, and are hardly ever used by professionals.
10/14/2018 2:41:00 AM • Black & Decker... • Answered on Oct 14, 2018
Where in Dubai can I buy battery for my Black & Decker screw driver model K60H H2 3.6V
Hello, Mukund - I am answering from the USA. There is a Stanley Black & Decker (the current name of the Black & Decker Company) business in Dubai. See the location information here: http://placesmap.net/AE/Stanley-Black-Decker-197888/ You can contact them by phone and ask about a battery for your screwdriver. Best wishes.
7/2/2018 4:17:51 PM • Black & Decker... • Answered on Jul 02, 2018
Unable to register
Had this question before, try this site Myblackanddecker.com and see if that helps, if not let me know and I will dig deeper into their files for you.
6/7/2018 6:39:15 AM • Black & Decker... • Answered on Jun 07, 2018
Red light flashing from electric drill black & decker 504re type 2 240 volt
Keep turning it off and on several times at the socket sounds like you need to trick the memory Good luck
12/17/2017 3:55:16 AM • Black & Decker... • Answered on Dec 17, 2017
Black & Decker Dewalt No.DW505 Heavy Duty Vsr Dual Range Hammerdrill 7.8A Logo
1 questions posted
Top Black & Decker Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Drills
Most Popular Question
need wiring diagram dw505 2 trigger
  • Drills
