20 Most Recent Samsung SMH7159 Microwave Oven Questions & Answers
2answers
Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
12/10/2022 7:22:29 PM • Samsung SMH7159... • Answered on Dec 10, 2022
0answers
Grandson came up under it and caused the hinges to
If the door doesn't work right it is time to buy another microwave. Microwave leaks can be dangerous.
10/21/2013 1:17:53 AM • Samsung SMH7159... • Answered on Oct 21, 2013
Microwave door
It sounds like the mount which holds tension on your door latch heads (door hooks) is broken. You can confirm that by pushing up on the door hook. If it goes up with no real resistance, the spring is unhooked. Fixing that would require disassembly of the door (by separating the panels) and repairing or replacing either the door hook assembly or the door panel inside.
1/21/2009 1:50:06 AM • Samsung SMH7159... • Answered on Jan 21, 2009
The Microwave stopped heating
Probably magnetron failure- needs to go back to the dealers, this is a major job, may be cheaper to replace the oven
1/9/2009 11:46:47 AM • Samsung SMH7159... • Answered on Jan 09, 2009
My microwave is in timer
unplug for five min then try it again!
12/11/2008 4:44:43 AM • Samsung SMH7159... • Answered on Dec 11, 2008
Smasung MW7490w door/turntable problem
It's probably a defective door switch, probably the upper one, or the mount which holds the switch is broken. Opening the door while cooking (without first hitting the STOP button) is the primary cause of door switch failure. There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door. The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly. Usually it's not a loose screw, but instead a broken tab on the switch holder, allowing the switch to rotate just out of position.
9/23/2006 8:00:06 PM • Samsung SMH7159... • Answered on Sep 23, 2006
My Samsung microwave won't turn on
There are many other components that can fail. A Samsung is worth getting professionally repaired. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
9/1/2023 12:08:01 AM • Samsung... • Answered on Sep 01, 2023
Samsung smh1816s fan comes on when door open and now whole unit is dead.
where did you buy it?
8/15/2023 1:53:04 PM • Samsung... • Answered on Aug 15, 2023
Samsung microwave oven model #ME21K7010DS/AA
Judging from reviews of this model on Samsung's website, this is a common problem. Does it happen during or after using the cooktop or range below the microwave oven? In particular, is it most common when using the burner directly under the microwave oven control panel? If the issues are correlated to heat or humidity from cooking on the range top, I would suspect problems with moisture in the keypad circuitry. I would consider cleaning the controller board key panel connector area with 90%+ isopropyl alcohol (this is an internal service on a circuit board that is most likely susceptible to damage by static electricity, so it should be done by someone who knows how to service electronics). This should remove contaminants that could cause current leakage between keypad connections (spurious keypad entries) in humid conditions. Let the board dry thoroughly before reconnecting. It's also possible that moisture is getting into the keypad assembly. This would be a design/manufacturing flaw. I would guess the oven is out of warranty, so the fix would be to put the keypad in a dessicator for a day or so, then seal the edges with RTV Blue or a similar caulk that does not release acetic acid (vinegar) during the curing process. (Acetic acid even in vapor form may corrode the silver contact material in the keypad.) Do not seal the connector, just the edges of the flex ribbon layers where moisture can get into the key membranes. In the meantime, always use the microwave oven fan when cooking on the range. This will help to keep the controller cool and dry. (Samsung's troubleshooting guide says the fan will turn on automatically if the microwave oven gets too warm from cooking underneath it.)
3/16/2023 8:51:25 PM • Samsung... • Answered on Mar 16, 2023
Hi i have Samsung Model GE0103MB microwave and i took it for repairs and the bottom switch is not engaging
It sounds like you are having difficulty with the bottom switch on your Samsung Model GE0103MB microwave not engaging with the door release button. This can prevent the microwave from functioning properly and could be caused by a few different issues:
  1. Make sure that the switch is properly connected to the door release button. The switch may have been installed incorrectly during the repair process, which could prevent it from engaging properly.
  2. Check the door release button to ensure that it is not damaged or malfunctioning. The door release button could be preventing the switch from engaging properly.
  3. Check the wiring connections to the switch and door release button to ensure that they are secure and not damaged.
  4. If you are having difficulty assembling the microwave, I suggest you to try and get the service manual or a diagram of the assembly process for your specific model GE0103MB. You can try searching for it online or contacting Samsung customer service, as they may be able to provide you with the information you need.
  5. If the problem persists, you may want to contact a qualified technician to service the microwave and inspect the door switch and door release button.
It's important to note that working on a microwave oven can be dangerous and should only be attempted by someone who is familiar with the inner workings of the device, and have the proper tools and equipment.
1/14/2023 10:45:45 PM • Samsung... • Answered on Jan 14, 2023
Samsung MW82Y microwave acting strange.
Now you know why they were selling it, it doesn't work and needs dealer service! https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
12/23/2022 5:16:55 PM • Samsung... • Answered on Dec 23, 2022
I have a Samsung ME18H704SFS- overheating help.
It will be fine. They aren't made for sustained cooking on high power. Popcorn is dry but oiled, so it gets very hot and burns. You can use the glass carousel plate or replace it. Depending how big the crack is, any water in the crack will finish it off. A new glass tray is $57. A new Microwave the same is $319. Samsung are one of the better makes. https://www.google.com/search?q=samsung+me18h704sfs+replacement+glass+plate ..
11/27/2022 3:04:28 AM • Samsung... • Answered on Nov 27, 2022
2answers
Got nc error code on my roadmate can anyone help
Nc means theres most likely an inverter fault inside the oven. This can be repaired cheap. Contact me for info.
7/10/2022 1:23:07 PM • Samsung... • Answered on Jul 10, 2022
Samsung SMH2117 microwave oven.
7/7/2022 3:02:28 PM • Samsung... • Answered on Jul 07, 2022
Samsung microwave door wont close
The small plastic plate on the microwaves door with the spring it it needs to be replaced.
6/29/2022 1:38:18 AM • Samsung... • Answered on Jun 29, 2022
Samsung SMH7159 Microwave Oven Logo
17 questions posted
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Microwave Ovens
Most Popular Question
microwave door
  • Microwave Ovens
